need some help/ info
  • Thread starter Thread starter Dan88_5.0
  • Start date Start date Dec 8, 2008
Dan88_5.0
22
Hermiston
Dec 8, 2008
  • Dec 8, 2008
what carb and lower intake manifold would be good for a 1988 efi 5.0 im selling the motor to my buddy and he wants to carb it and we need to know how to do so cause it is an efi car and is it possible ive only been versed in fuel injection so i need some help
D
Deleted member 87397
Dec 8, 2008
  • Dec 8, 2008
Is the motor going into another Stang? Will it see higher rpm ranges or be street driven? Like you mentioned before you are going to need an intake manifold and carb. Also a mechanical fuel pump and possibly a regulator and maybe a distributor with a vacuum advance, but I'm not 100% certain on that one. There are tons of manifold/carb combos out there. If it's going to be street driven and it's a basic bolt on motor a nice dual plane Edelbrock Victor manifold and a 650 cfm carb should do the trick. Really we need more info on how built this motor is going to be to make the best suggestions. Also, if this engine is going into another Stang that was fuel injected, the fuel system itself from the tank forward will need some work. Also try doing a search. I'm sure there's tons of info on here about converting to carb.
Dan88_5.0
22
Hermiston
Dec 9, 2008
  • Dec 9, 2008
it will be street driven. and the car that the 88 efi 302 will go into is a 1985 lx notch... hence why he wants to carb the motor. also did late 80's and early 90's f-150's have a t-5????
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,238
2,942
224
Vass, NC
Dec 9, 2008
  • Dec 9, 2008
definitely a tech question... moving there
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
D
sad day
  • davecobra2
  • Jul 13, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 22, 2026
davecobra2
D
A
need help and advise
  • amps1956
  • Oct 14, 2025
  • Other Auto Tech
Other Auto Tech Oct 21, 2025
Mcmahst
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
