  • SN95 4.6L Mustang Tech
Need some help (Video Included)
  • Thread starter Thread starter dallas2002GT
  • Start date Start date Mar 8, 2006
D
dallas2002GT
52
  • Mar 8, 2006
Awful whistling noise coming from the engine bay. Also at the very end of the video keep your eye in the left exhaust tip and tell me what you think that is blowing out of it.
http://media.putfile.com/Whats-this-noise-from
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 9, 2006
  • Mar 9, 2006
does it run awfull? does it have a cel on.
sounds to me like a vacumm leak. now keep in mind the IAC when the engine is cold can make that air sucking sound too.
the water out the tailpipe is normal.
first thing to test this is to hold the throttle slightly open i mean very slightly and pull the electrical connector off the iac while running. it the noise goes away it's the IAC valve ( and if the engine is cold this is normal)
if the noise is still there. what you can do is feel around the vaccum hoses and iac area and see if you can make the nosie change. it you can there is your vacumm leak.
do this and come back if you can'tfind it. then you can do the carb cleaner test.
01Steeda
732
Baton Rouge, LA
Mar 9, 2006
  • Mar 9, 2006
I wouldnt worry about the water coming out of the tailpipe. My car didnt really do that until I had the cams put it, but it does now.
sgarlic
3,085
Mar 9, 2006
  • Mar 9, 2006
That's condensation from the tailpipes, nothing to worry about. Get behind a Kia sometime in traffic and watch how much condensation pours from their tailpipes when they take off.. our van pours out a TON.
Your video to me sounds like a vac leak, but you say you checked over everything, so I guess you can eliminate that if you're sure. Good luck .. and try the IAC advice above.
1LowGT
294
st louis mo.
Mar 9, 2006
  • Mar 9, 2006
try spraying carb cleaner around the bay,if idle changes you found the general area.
Mike97gt
it doe snot
10,633
Mar 10, 2006
  • Mar 10, 2006
ok any news yet? it helps to post back when you find the problem
Shiroelex
There's nothing worse than aut
728
Westland, MI
Mar 10, 2006
  • Mar 10, 2006
I'd check the connections at the rubber intake tube to the IAC hose for leaks first. Then, I'd unplug the hose at the IAC, and stick your thumb over the iac side and in the hose, and see if the noise goes away. If not, then check the rubber vaccum nipple thing on the bottom front left of the upper plenum, that has two red plastic lines coming out of it, Mine had a small hole in it for some reason, and was leaking there.
D
dallas2002GT
52
  • Mar 10, 2006
I cleaned the IAC and sprayed carb cleaner around the intake and hoses. Nothing happend. I am starting to think its a pulley or something of that nature. I guess I will just deal with it.
My raptor shift light started going off randomly as well. I can be cruising at 2 grand and it will start circling like I just turned the car on. I checked the ground and power wire and everything is secure
If I didn't already have 2,250.00 invested in after market crap I would trade it in and get a 03/04 Cobra.
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
1998 Mustang Gt Rattling sound, cannot locate. Video included
  • studerman1
  • Mar 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2026
studerman1
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
