- Feb 24, 2008
- 17
- 1
- 0
OK, my 2003 GT started throwing a SES light at me the other day. Pulled the codes and got four things-both downstream O2 sensors and P0171 ans P0174 both banks running lean. I checked out the O2's and did end up replacing them, one was definitely shot so I just swapped them both. Reset, and still getting the P0171/P0174. After doing some digging on this forum, I see that this is most likely a vacuum leak, problem is I do not see anything wrong with any of my vacuum lines. Motor is stock and has not had anything removed from it recently that would cause this issue. Is there any likely place that tends to cause this issue, or could this vacuum leak be basically anywhere? Also, is there an easier way to tell where the leak is? A visual inspection turns up nothing, I removed, checked, and then put back on every vacuum line I could get my hands on, with no luck. Removed and reinstalled my air filter/intake tube just to check, no difference there either. Any thoughts?
