Need some help????
Bryce'sStang
227
MN
I can't seem to find any decent help anywhere on the internet except here. So my question has to deal with my 95 F150 with a 351w. I have a high idle sometimes and it stays there. I pull the plug from the IAC and it idles good. Is this the problem. By the way it is speed density!!!
Thanks
run the KOEO(Key on engine off) and KOER(key on engine running) tests and reply back with the codes (if any) and when KOEO or KOER they came up.
i ask you to do this because the tests check the IAC operation.
Thanks
Bryce, I know it's been a while... but, any updates? Did you get it fixed? I ask this because I'm having very similar problems with my speed density 5.0 in my Mustang :bang:. Borrowed an IAC from a '91 Grand Marquis 5.0, same results. Maybe a vacuum leak?
