Need some help
  • Thread starter Thread starter darkness falls
  • Start date Start date Feb 4, 2004
darkness falls
112
Kansas
Feb 4, 2004
  • Feb 4, 2004
I want to know if my engine compartment is bent or what. So what would be the angles of the engine? There are some things bent that make me believe that it might have been hit in the pass. font corner
Secondly, what trans went with the 390FE?
I have pics of the engine compartment that I will post in a day or so, need to get them developed.
and, how to open the trunk when locked...Yeah it is kinda a stupid question but don't really want to mess things up more than it already is.
My car is kinda a piece, but I get tired of people saying that its **** and why did you buy it. Yeah it is going to take a lot of time, and money but I didn't expect to get this done in a month yeah know. Just got to take it slow. and the car isn't as bad as I have seen others, yet they get fixed up.
rbohm
6,698
550
204
tucson,az
Feb 5, 2004
  • Feb 5, 2004
the 390 came with either a cruise-o-matic(pre 1966), a C6(post 1965), or a top loader 4spd. not sure about engine angles, but if you pick up a shop manual for your car, it will tell you what measurements you need to look for to tell if the engine compartment is square or not. if you can remove the rear seat, you should be able to get to the trunk lock. use a pair of needle nose pliers, and locate the lock itself. you will see the rod that operates the lock. turn this rod with the pliers and the trunk should pop open. then you can either replace, or repair the trunk lock. and dont let people who are jealous of your owning a vintage car get you down. invest some time and money on your car, assuming you like it enough to do so, and restore the car as you like. and tell the morons to bugger off.
D
D.Hearne
11,730
south louisiana
Feb 5, 2004
  • Feb 5, 2004
390's also came with the Toploader 3 speeds too.
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 5, 2004
  • Feb 5, 2004
As to the appearance of the engine compartment, it would be a simple matter to compare yours with another similar car in good condition. A "bent" compartment would be best be deternined by such a comparison or measurements based on factory specs. See the Ford assembly manual.
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Jun 14, 2026
Mindseye007
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
A
Please!? I need some help with my 1964.5 alternator conversion
  • Alabear94
  • Dec 6, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
GOvert
G
A
Help ID - Turbo GT, SVO differences
  • aldoelmalo
  • Jun 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2026
aldoelmalo
A
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
