  • SN95 4.6L Mustang Tech
Need some help.
  • Thread starter Thread starter 02trublu
  • Start date Start date Jun 7, 2007
02trublu
houston/lubbock
Jun 7, 2007
  • Jun 7, 2007
as i was pulling into my driveway this evening, my dad noticed that my reverse lights were on. so i proceeded to check it out and even after turning the car off and then restarting it the lights still stay on. i ran through the gears and they still stayed on.
any suggestions before i get a ticket driving to work tomorrow.
02trublu
houston/lubbock
Jun 8, 2007
  • Jun 8, 2007
ttt
D
Dragstr05
643
Stafford VA
Jun 8, 2007
  • Jun 8, 2007
I cant say exactly without looking at a wiring diagram, but you either have a problem with your back-up switch, or you have a short to power/ground. But I cant say which without looking at a diagram. You have a wiring issue nonetheless.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jun 8, 2007
  • Jun 8, 2007
Very possible the reverse light switch on the trans has failed.
Not hard to change, but hard to reach. It will look like a little spark plug on the side of the transmission with a 2-wire harness plugged into it.
If you have a meter you may want to test it first. Pull the harness off and test for continuity between the two prongs. It should only be closed when in reverse and open in neutral or any other gear. If it's closed in all gears, replace the switch (don't remove it and drive the car to the dealership, fluid will come out of the hole)
02trublu
houston/lubbock
Jun 9, 2007
  • Jun 9, 2007
thank you sirs.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
