Need some input!
  • Thread starter Thread starter Cobain03
  • Start date Start date Aug 14, 2006
Cobain03
996
Lexington, Ky
Aug 14, 2006
  • Aug 14, 2006
we are running out of ideas...
http://media.putfile.com/engine-13
im having valve problems. int he video, you can hear a "chatter" from the exhaust valve on number 8 cylinder. no matter what you do, it will not quiten down. we thought, maybe the cam lobe wore off. but we checked it by measuring a rod (dubbing as the pushrod) ontop of a good lifter at TDC and then at the bad one at TDC. same thing. now, since thats eliminated, thiking that it could be a valve thats either burnt, hitting the head, or a guide is not seated properly. you can put pressure on the sping while the car is running and it hushes up.
and before anyone asks, its not loose header bolts.
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
T
302 stepchild needing some valvetrain guidance
  • timdhawk
  • May 7, 2020
1974 - 1978 Mustang II Talk & Tech May 8, 2020
Enzio
E
For Sale 1989 LX Notch 410ci 85mm turbo 8 pt cage 9" rear end
  • EightyNineFive
  • Aug 22, 2021
5K
Fox Body Mustangs For Sale (1979-93) Jun 18, 2022
Freakinstang
F
Issues with the Mach 1
  • 67fastbk
  • Jun 6, 2018
1965 - 1973 Classic Mustangs -General/Talk- Jun 6, 2018
67fastbk
Old H/c/i Installation Explanation And Pics
  • FastDriver
  • Jan 26, 2018
2K
Fox 5.0 Mustang Tech Jan 27, 2018
FastDriver
