  • 1994 - 1995 Specific Tech
Need Some Quick Help!
  • Thread starter Thread starter 95socalstang
  • Start date Start date Aug 29, 2005
9
95socalstang
29
So Cali
Aug 29, 2005
  • Aug 29, 2005
My stang is acting a little weird...When I went to start it yesterday after work it started up fine and then the RPM's starting jumping around as well as the Battery Gauge...I turned it off and let it sit for 5 min and then it started up fine and I drove away..Well after work today it did the same thing...RPMS go nuts and battery gauge goes from the empty line and then back up. I have changed my battery twice in the past 6 months(DieHard Gold) and have a pretty new alternator on there. Any ideas on what this could be? Its been very hot lately in Southern cali...Any chance that the battery is getting too hot under the black hood? LMK quick so that I can get this problem solved! Thanks a million!
Eric
HISSIN50
34
129
Aug 29, 2005
  • Aug 29, 2005
I might check the power distribution bolt/connection to ensure it is not corroded and that it is tight. Ditto for the alt connection.
You can have the system tested on the car if this happens often enough.
Also, you can yank codes and see if the puter stored anything during one of the car's fits.
Good luck.
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
A
Please!? I need some help with my 1964.5 alternator conversion
  • Alabear94
  • Dec 6, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
GOvert
G
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
