  • 2.3L (N/A & Turbo) Tech
Need Turbo help
  • Thread starter Thread starter rd
  • Start date Start date May 22, 2006
rd
3,316
63
109
Ocean Springs MS
May 22, 2006
  • May 22, 2006
The turbo on my 86 TC has the oil line disconnected, so I assume it is toast.
What are the options for fixing one of these? Can you replace the bearings and seals, or do you have to replace the whole unit with a rebuilt?
What makle or model turbo should this thing have?
Thanks, I will get a book soon, but I am rounding up info on it until I get there.
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
May 22, 2006
  • May 22, 2006
Last month's 5.0 Mag (I think, it may have been MM&FF) has an article on rebuilding the factory turbos. IIRC they got a rebuild kit on Ebay that had all the bolts and gaskets needed. Might be in the tech section on one of their respective websites.
EDIT: If you can't find it, let me know and I can scan it and pm it to you.
88stangmangt
2,332
Stafford,VA
May 22, 2006
  • May 22, 2006
should have a little IHI turbo...it might be cheaper to just upgrade to a garret t-3 off a turbo coupe or so they should make a couple extra hp. parts are cheap and easy to find....and it uses the same manifold.
evintho
20+ Year Stangneter
Nov 12, 2003
683
246
73
Santa Rosa, CA.
May 22, 2006
  • May 22, 2006
The '86 came with the larger T3 turbo. Look it over. IHI's had IHI stamped on the turbo and only came on '87-'88 TC's. Towards the bottom of your compressor housing should be stamped either AR 63 or AR 60. The AR 63 would be the larger turbo. I believe they came on '83-'86 TC's. The smaller T3 came on XR4ti's.
Rebuild kits are available................................
http://cgi.ebay.com/ebaymotors/GARR...ewItemQQcategoryZ33742QQitemZ8066793097QQrdZ1
but it would probably be worth your while to just buy a used T3 off of Ebay or Turboford.net.
rd
3,316
63
109
Ocean Springs MS
May 23, 2006
  • May 23, 2006
Thanks. I looked for that article for an hour Sunday and could not find it. I will look again!
Did not work on the beast yesterday. This may go on hold. Several other demons are threatening.
Trying to get my old Waverunner tuned up and ready to sell. I hate working on old, aluminum engines.....If you drop stainless bolts, you cannot get them back with a magnet.....
Runs great, but needs the head cover gasket.
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
D
Electric turbo
  • Doug76
  • Mar 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- Mar 11, 2025
