Needs Opions
  • Thread starter Thread starter herb huffman
  • Start date Start date Oct 28, 2017
H
herb huffman
  • Oct 28, 2017
picked up a 1990 foxbody ... 302 bored .30 over , f-cam , 24lb injectors , windsor heads , 202/160 valves , 80mm throttle body , 373 gears , cold air and maf... still has stock distributor on it and want to upgrade ... opinions ? still stock computer... opinions ? has summit 75mm maf sensor ... shouldn't it match the throttle body ? please help
2000xp8
SN Certified Technician
Aug 8, 2003
8,062
1,647
194
NJ
Oct 28, 2017
  • Oct 28, 2017
What intake?
80mm TB is huge, most intakes have to be ported to accept it correctly.
The stock distributer is better than any aftermarket replacement.
Typically the maf is larger than the TB, but it's probably fine.
A summit 75mm meter is probably a rebadged pro m, so it should be fine.
Those parts aren't anything the stock computer can't handle.
Reactions: General karthief
H
herb huffman
  • Oct 28, 2017
2000xp8 said:
What intake?
holly systemax intake upper and lower
2000xp8
Aug 8, 2003
8,062
1,647
194
NJ
Oct 28, 2017
  • Oct 28, 2017
I'm not sure what the systemax comes with for an opening, if these other guys don't answer, just pull the intake tube off and look to see if there is an edge where they meet.
If the car runs good, you may not really need any help.
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
D
No start
  • dkrupp79
  • May 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2025
dkrupp79
D
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
