Neutral is Sticky.
  • Thread starter Thread starter sunil6784
  • Start date Start date Apr 19, 2005
sunil6784
620
Boston, MA
Apr 19, 2005
  • Apr 19, 2005
HI everyone,
I just got my new stang, its a 92 LX 5.0 Special Edition. Just picked her up today. I'm very happy so far, except for one thing. THe car is a 5 speed. When the shifter is in neutral, if i move it to the left, the shifter seems to want to stay all the way to the left, like its a little bit sticky. But if i move it to the right, as if to engage reverse or 5th, there is a little bit of grinding. There is no whine or anything while its in gear, and it engages all gears fine. This only happens in neutral. Could it be gear oil ?
HISSIN50
34
129
Apr 19, 2005
  • Apr 19, 2005
WC T5's use ATF only! an aftermarket shifter might help with the stickyness. check the trans level or flush/renew the fluid. it holds 2.7 quarts.
good luck and congrats on the new ride!
Stang8URMPRT
1,100
Daytona Beach, FL
Apr 20, 2005
  • Apr 20, 2005
My car does the same thing... Sticks in the 1-2 area when pulled to that side. Doesn't bother me though. I don't see it as a "problem", but your grinding is a problem. Do what HISSIN said first. if that doesn't cure it... Might be time for some syncros and/or gears depending on how long it's been grinding.
HISSIN50
34
129
Apr 20, 2005
  • Apr 20, 2005
yeah, i should have said why i posted that a new shifter might help. the lateral springs (if a stock noodle, i mean shifter) might have fatigued. this would mean it does not want to return to center very well (making finding 3rd quickly hard). a new shifter will have more aggressive springs to help it return to center.
i just re-read the original post: with what you said, it sounds like the shifter itself is actually making the grinding (not engagement of the gears?) - if so, even more reason to swap a shifter on there.
good luck.
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
Hammer shifter problems
  • 387lx
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
General karthief
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
