Neutral Safety Switch after AOD to t-5 Swap
Mustang_Punk
224
Sac, Ca
Hey,
I just put the t-5 pedals in but the yard I got they from broke the NSS, I don't wanna run it anyway, does anybody know what wires I need to splice (if any) to disable this switch?
Also, I here I need some sort of loopback connector on my trans for reverse lights, anybody know where to get this?
Thanks!
the clutch safety switch is already bypassed/jumpered in an automatic car (all were wired for sticks from the factory) so you dont have to mess with wiring for that switch at all. the only thing youll have to splice together is on the old harness going to the automatic, i forget what color they are but if you have a chiltons manual theres a wiring diagram in the back that will tell you. the other two wires in that harness are for backup lights, i just used a couple crimp-on bullet connectors for mine and it works fine.
im going to take a wild stab in the dark and say that if there is no clutch pedal then there is no clutch switch and you should be okay there. also, the wiring harness for the aod should be the same, pick up a haynes or chiltons or w/e for the car to help you with what two wires are backup lights and which two are for the trans neutral switch. splice the later together.
