So I finally have time to put new gears in. (3.55) What else should I get with them?
I know I will need an istallation kit which comes with
Pinion Seal
Carrier Shims
Crush Sleeve
Pinion Nut
Cover Gasket
Ring Gear Bolts
Brush
Gear Marking Compound
Loctite
Or should I just go with the bearing kit
Front & Rear Pinion Bearing
Pinion Seal
Carrier Bearings
Carrier Shims
Differential Bearings
Crush Sleeve
Pinion Nut
Cover Gasket
Ring Gear Bolts
Brush
Loctite
and twice the money?
like 75 which is worth it I guess
Also I know this is a stupid question
but a stock 95 gt has an 8.8" rear end right? cause I dont think it is a 7.5"
Now I run 285/35-18 in the rear for tires how much will the new gears with the tire combination mess with the speedo and odometer? and what can I do to fix this?
I dont want mystery miles on the car
or at least not alot
In a way it doesnt matter considering the odometer is at 120000 but the engine in now before the rebuild was at 60000 and that was rebuilt and currently has no miles since
also I know alot of people like 3.73 gears but it is just not practicle for me to run cause I still use the car as a highway driver and most of the week driver.
Pinion Seal
Carrier Shims
Crush Sleeve
Pinion Nut
Cover Gasket
Ring Gear Bolts
Brush
Loctite
Pinion Seal
Carrier Bearings
Carrier Shims
Crush Sleeve
Pinion Nut
Cover Gasket
Ring Gear Bolts
Brush
Loctite
but a stock 95 gt has an 8.8" rear end right? cause I dont think it is a 7.5"Now I run 285/35-18 in the rear for tires how much will the new gears with the tire combination mess with the speedo and odometer? and what can I do to fix this?
or at least not alot In a way it doesnt matter considering the odometer is at 120000 but the engine in now before the rebuild was at 60000 and that was rebuilt and currently has no miles since
and give my girlfriend wiplash when she is in the car.
