New 347 drive without tune?
  • Thread starter Thread starter speedtrip
  • Start date Start date Aug 5, 2009
speedtrip
93
Jerkwater, U.S.A
Aug 5, 2009
  • Aug 5, 2009
I just installed fuel injected 347 in my 87 notch . It idles and drives good in short rides around neighborhood. I was wondering if its alright to drive without getting it dyno tuned? Ill be breaking the clutch in for 500 miles so ill be taking it easy. Id like to get tune this winter but dont have $ right now.
Also i bought and installed a used bbk 75 mm TB that has 2 small holes drilled in Throttle plate. Im guessing this was to improve his idle? BBK said i cant buy plate i can sendit to them to replace for $50. Should i bother if my idles good?
rbonella
409
@ home
Aug 5, 2009
  • Aug 5, 2009
there are a lot of unknowns with your tune right now. Dyno time with a tuner is great insurance and peace of mind. Plus you more than likely will extract more performance from the motor after it's been tuned. You didn't mention any details about your fuel system which is very important, plus ignition and timing. A tuner can tell you if you have enough fuel throughout the power band, you could lean out the first time you past lets say 4500 rpm and then you could hurt the motor. Like i said...lots od unknowns. I would save $ quickly for a tune. Regarding the tb, I never fix anything that isn't broken! That's me though
speedtrip
93
Jerkwater, U.S.A
Aug 5, 2009
  • Aug 5, 2009
I have 255 fuel pump and pro m 80 calibrated for my 30 lb injectors all new. New msd digital 6 al2 new cap rotor plugs and msd wires.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Aug 5, 2009
  • Aug 5, 2009
run base timing at 12 degrees , fuel pressure at 39 to 41 with vacuum off and plugged and it should be fine to drive , but I wouldnt beat on it till you get the air/fuel checked with a wideband
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Aug 5, 2009
  • Aug 5, 2009
You should be fine, people been running 5.0's worked for years before dyno's or wide bands even existed.
2002's advice above is pretty good. Make sure to run 92 or better gas. You can experiment with a little more timing, if it pings back it down again.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
  • dan50
  • Jul 18, 2026
dan50
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
