New best.. cams w/ stock heads & intake
must2j said:
nice 1/4 times... did you have to change your breaks to get those welds to fit your stang. I was told I had to change my breaks to put 15" welds on my gt.
On 99+ GT's, all you need is a 7/16" spacer on your front hubs for the skinnies. The rear 15x8's or 15x10's will fit fine with the 5.5" and 6.5" backspacings (respectively). On 94-98 GT's, you'll need the 7/16" spacer, but you'll have to grind the calipers down a bit, too.
Kurgan said:
There's a tube that runs between your header and your intake manifold. I capped off where the tube plugs in on the header and cut a plate of aluminum and put it and the EGR gasket in place over the opening on the intake for the EGR. I pulled the tube and valve out of the car completely and blocked off the vacuum lines for it. It sets off an SES light, but I have the EGR disabled in my tune.
what does this accomplish, just out of curiousity. i'm not being a wise ass, i really don't know
Bullett003 said:
About the MPH..... uhhh.. how come it gained so much in the 1/8 and nothing in the 1/4?!?!? :shrug:
By reading the time slips, it appears as though it is being chocked down by the stock intake manifold on the big end. Add a better intake and he should see that 4mph gain out the back door as well.
Scott.
Scott.
I didn't realize how little the stock ones where I guess, that seems like a lot of restriction.... could this be done by simply porting the stock one instead of buying a $1200 intake?
nice times man.
so far the PI intake is the best bet until the fox lake intake comes out. The buillitt intake is just waay expensive for me.
And for those who question 2 tenths, It takes a good 20~30 hp to drop 2 tenths when you're running high 12's. For what I would estimate he paid around $550~$650 for the cams and springs, 25ish HP is a STEAL.
Actually I can attribute a lot of it to the fact that I have trouble powershifting to fourth gear at anything over 6000 RPM. I'm taking third all the way up to about 6500 RPM before shifting to fourth. I was running 1st, 2nd, and 3rd gears all the way up to 6500 RPM, and I had to make a slower shift to 4th. I guarantee if I can start nailing some 4th gear powershifts, that mph should go up to 108+.
That, and like VTEngines said, my stock intake may be holding me back a little!!
