New block..Oil pump failed
  • Thread starter Thread starter vtecwho
  • Start date Start date Jun 5, 2009
vtecwho
61
  • Jun 5, 2009
..Oil pump failed **UPDATE..NEW 331 COMBO**
Long story short, I let my car war up and after about 5 min of idle i noticed i had no oil pressure. I noticed slight lifter clacking and thats when i noticed the oil pressure.
I checked the gauge and it was working. I even unscrewed the supercharger oil feed line then started the motor back up for a couple of seconds and agian, no oil....
Im guessing the oil pump failed and i dont care to trouble shoot it, i have been wanting to build it anyways so thats what im going to do.
since i have a stock block and 10lbs of boost, a new, stronger block is needed.
I just dont see the sense in re-building or replacing the oil pump in a block that will probably split soon anyways.
my plan was to go all out. I have been anticipating this and have money to put into it.
Im planning on getting new tranny, probably Gforce, and a new block with all new forged internals.
i want to put a dart sportsman block in there but have not decided what internals to get. i will be increasing boost by getting a T-trim so im prepared to spend what ever i need to to make it bullet proof. My HP goal is about 550, with comparable torque.
let me hear some of you thoughts and experiences!!
thanks guys,
Eric
P
PJC Racing
199
  • Jun 6, 2009
For your current block, you probably twisted the pump drive shaft.
Block recommedation...Man-O-War
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Jun 6, 2009
  • Jun 6, 2009
talk to rick he will help you out, thats what I would do. You want someone to build the engine with your end goal in mind, that has done many of them. I had mine built by a NMRA guy and i have never had a problem and they are not so expensive like buying a long block from off someone's "shelf"
good luck,
vtecwho
61
  • Oct 16, 2009
Its been a long road getting everything together so I thought I would sum it up and let everyone know how it went.
check out the link and see......
EECTuning.org • View topic - head/cam combo with 331 **finished biuld**
bmo37
2,368
New Jersey
Oct 17, 2009
  • Oct 17, 2009
thanks guys,
Eric
probably snapped the oil pump drive shaft, as for that g-force tranny my little brother has one in his stang and I can tell you the thing whines really hard with those straight cut gears, and shifting sounds like someone threw a engine block out the window. That tranny is heavy duty.
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
