  • 1994 - 1995 Specific Tech
New Carpet Install...Question
  • Thread starter Thread starter 94GTLaserRC
  • Start date Start date Dec 26, 2005
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Dec 26, 2005
  • Dec 26, 2005
Merry Christmas....Just got back from a weekend at Disney.
Im considering for about $100 swapping out my tan carpet for some new black carpet.....gives me a small projecto to keep me motivated for awhile....
I know time is probably more of a factor than the actual physical work, but my main question is: Is there a link or website that has simplied step-by-step instructions on how to do this? I think if Im not mistaken, it's a 3-4 hour job.
Any help would be appreciated.
Thanks
RC
bimmertech
1,123
merriam, ks
Dec 26, 2005
  • Dec 26, 2005
i dunno about a step-by-step, but i had my gray car completely gutted in about an hour.
it is pretty straight forward, the center console has some bolts around the e-brake that have to be removed, but other than that there is not any hidden screws. you will need a big torx for the seatbelt buckles, but no special tools are required. i do however reccomend you have a panel popper tool for ease of removal.
it looks like you already got sfc's, now is a good time to put in a cage.
oh yeah lay down some dynamat too while your at it.
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Dec 26, 2005
  • Dec 26, 2005
Listen to this guy, now that I put in my new carpet, the tranny tunnel is louder and gives off more heat. One of these days aim going to dynamat the whole floor...i like it quiet in there.
Once you pull your seats and your console, youll see what you need to do to get that carpet out..its really not that big of a deal.
94GTLaserRC
11,178
Dec 26, 2005
  • Dec 26, 2005
Thanks Bim...Thanks Kevin....Any links to purchasing the dynamat, and why it is "worse" when you change the carpet (heat/sound?)
RC
bimmertech
1,123
merriam, ks
Dec 26, 2005
  • Dec 26, 2005
http://store.summitracing.com/default.asp?target=/egnsearch.asp&N=400319
take your pick.
usually the aftermarket carpet sets have less insulation--hence more noise/heat. even if it doesn't have less insulation, it is always nice to quiet down the car. hey you're half way there, why not.
94GTLaserRC
11,178
Dec 26, 2005
  • Dec 26, 2005
take your pick.
I know you said "take your pick" but Im really confused on which one of those it would be. They are ALL different price ranges and styles (door panels, hoods, etc).
Throw me a bone
RC
bimmertech
1,123
merriam, ks
Dec 26, 2005
  • Dec 26, 2005
dyc-10125, 10145, 10155--this is the original mat, comes in a roll of 4, 13, 36sq ft respectively. $20, $60, $170
dyc-21205 is the big badass and comes in a 6sq ft roll only--this stuff is heavy, but rules all. $80
one layer of the regular and one of the badass will be close to .5" thick. so if you bought mass back carpet--without insulation--then i would go 2 layers regular and 1 of the badass. if you bought carpet with insulation, then go 1 layer of regular and put the badass in strategic areas like around the trans tunnel and up around the firewall.
one layer will be enough in the door panels and headliner. as for the trunk i would use 2 layers of the regular unless you have a rear seat delete kit, then go 3 layers.
sorry bout the confusion, hope this helps.
94GTLaserRC
11,178
Dec 26, 2005
  • Dec 26, 2005
Thanks again...got an idea as to how much I would need to just do my carpeting for now?
(Just one layer is fine...I dont need to go all out.. as long as Im better than stock Ill be happy)
Thanks
RC
bimmertech
1,123
merriam, ks
Dec 26, 2005
  • Dec 26, 2005
you could get by with the 13 roll if you don't plan on doing the trunk or the door skins. it all really depends on what type of carpet you plan on getting.
could you post a link, i have mass back in my 94 with no dynamat and it is very loud, but it is a race car so who cares.
i am getting ready to do the 95 with insulation and daynamat but i haven't found a carpet kit that i like.
edit: it seems they call mass back something diff now. when i bought my mass back it came as a pre-cut carpet with nothing on the back side of the carpet. wtf do i know!!!!
slvrbullit302
986
Alabama
Dec 26, 2005
#10
  • Dec 26, 2005
  • #10
I replaced mine with a carpet kit from 50resto for about 160 with new floor mats. They use ACC carpets that are preformed, just have to do a little trimming in some areas but not alot.
94GTLaserRC
11,178
Dec 27, 2005
#11
  • Dec 27, 2005
  • #11
I havent decided on the EXACT carpets yet, but whenever I look through the ads in 5.0 Mag, I see bunch of places that sell the carpets for about $109-$119. I think MustangsUnlimited may be one of the places.
RC
Slvrbullit: is the carpet "kit" just the carpet, or does that include some type of padding?
Thanks
Install Daytona Sensors CD-1 Ignition Mustang Fox SN95
  • revhead347
  • Sep 21, 2019
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 11, 2026
AeroCoupe
New Gauges...Accurate? Well Made? Safe?
  • Wayne Waldrep
  • Oct 18, 2019
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2019
jrichker
Old H/c/i Installation Explanation And Pics
  • FastDriver
  • Jan 26, 2018
2K
Fox 5.0 Mustang Tech Jan 27, 2018
FastDriver
Fox T5 To Aod Conversion
  • 86GTVert#2
  • Jun 29, 2016
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 30, 2016
86GTVert#2
Progress Thread New To Me 96 Gt And A Couple Of Questions
  • Puggy_sd455
  • May 10, 2015
  • 4 5 6
11K
1996 - 2004 SN95 Mustang -General/Talk- May 22, 2016
Puggy_sd455
