new clutch slips
  • Thread starter Thread starter dastang2
  • Start date Start date Apr 13, 2004
1 of 2 Next Last
dastang2
2,020
tx
Apr 13, 2004
  • Apr 13, 2004
i got a new fly wheel and a new ford racing clutch but before the installation the flywheel got some surface rust on it. i just put it in like that and put everything together. the clutch slips a little and i was going to let the clutch break in for 500 miles. i was thinking that the clutch would rub the rusty area off and work fine soon or within the 500 mile break in time. what do yall think. it slips above 1st gear and not to bad, it tries to catch. i know i should have fixed the problem before hand but i just wanted it to go.
P
proxses
620
Dayton, Oh
Apr 13, 2004
  • Apr 13, 2004
The rust should have worn off the first time the clutch slips. It should not continue to happen. Kind of like the rust on a pair of brake rotors that has sat for a few days.
Are you sure it is adjusted properly?
You say it tries to catch. Does it slip under throttle after you let the pedal out? Or does it only slip as you shift?
5.0drager
tx
Apr 13, 2004
  • Apr 13, 2004
no, only when i apply a good amount of throttle is when it slips. how would i adjust it with a stock cable and quadrant, the clutch pedal has no play in it whatsoever. this is my wifes user name but still the same person. in 1st it works good, it gets squirly pretty easily with 3.08 gears.
P
proxses
620
Dayton, Oh
Apr 13, 2004
  • Apr 13, 2004
I'm not sure how to adjust it. My Ranger has a hydralic clutch.
But from what I have read, there should be a threaded end and nut were the cable attaches to the clutch fork. There is an adjustment someplace, hopefully someone with a Mustang will read this and respond.
But a new clutch should slip only as the clutch engages between shifts, and that should be unnoiticable. So something is wrong.
J
jerry beach
2,671
Ocala,FL
Apr 13, 2004
  • Apr 13, 2004
Where does your clutch start to engage? Up high by the brake pedal, or down low by the floor? Or is the pedal in the middle when you feel the car start to roll?
dastang2
2,020
tx
Apr 13, 2004
  • Apr 13, 2004
the cable has no treaded end on it, but the flywheel did have a good bit of rust on it, not the kind that would rub off with my finger or rag.but when it tried to grip, it made a shutter feeling like wheel hop or something but i do not think the tires were spinning. i think it was in 2nd or 3rd then. it shuddered then gripped. like i said, there is absolutely no play in the clutch pedal.
dastang2
2,020
tx
Apr 13, 2004
  • Apr 13, 2004
not to sure but if you wait a minute i will go check.
dastang2
2,020
tx
Apr 13, 2004
  • Apr 13, 2004
ok it starts to move at about even with my brake pedal when letting off of the pedal.
SLiM JiM 156
1,024
Rohnert Park, CA
Apr 13, 2004
  • Apr 13, 2004
wow thats way too far out, its should grab right when you start letting the clutch out..
dastang2
2,020
tx
Apr 13, 2004
#10
  • Apr 13, 2004
  • #10
well the brake is pretty far down there, yall think the cable could be bad
J
jerry beach
2,671
Ocala,FL
Apr 13, 2004
#11
  • Apr 13, 2004
  • #11
Yeah, its not your clutch, but the way you have it adjusted. You need an alum. quadrant and firewall adjuster. Or at the very least an adj. cable. You should not drive the car, and under no circumstances should you get on it if you do anyway.
dastang2
2,020
tx
Apr 13, 2004
#12
  • Apr 13, 2004
  • #12
how much would an adjustable cable cost, i heard that those did not fit right. would the firewall adjuster fit on the stock cable
J
jerry beach
2,671
Ocala,FL
Apr 14, 2004
#13
  • Apr 14, 2004
  • #13
A FWA should fit with the stock quad and cable, but there may be excessive wear on your cable. Take your cable out and make sure it runs easily through the housing. Mine was frayed and had a rough spot.
I mashed my clutch with my hand and watched the plastic quad flex under the tension. There was no way I was leaving that thing on there. It will shatter if you dont replace it, sooner or later.
dastang2
2,020
tx
Apr 14, 2004
#14
  • Apr 14, 2004
  • #14
it is a new from ford but i am leaning towards a used one from some folks from this site. the cable moves as freely as possible, i checked before the install. it is a used cam but looks to be in good condition.
dastang2
2,020
tx
Apr 14, 2004
#15
  • Apr 14, 2004
  • #15
anybody else have any advice or opinions, i am getting different bids on a new quadrant set
9
92Patrol5.0
1,076
Cedar Rapids, Iowa
Apr 14, 2004
#16
  • Apr 14, 2004
  • #16
You should have just paid the 30 bucks to have the flywheel resurfaced when you had it off. At least you could elminate that aspect and know it's not because of any rust. I did a clutch swap about 2 years ago. I recently dropped the tranny and clutch and all to check my rear main and swap the oil pan gasket. The flywheel was in excellent shape, but I went ahead and had it resurfaced just to be on the safe side when putting everything back together.
dastang2
2,020
tx
Apr 14, 2004
#17
  • Apr 14, 2004
  • #17
well i noticed when putting everything back together the new through out bearing did not want to come very far off of the new pressure plate. maybe a few cm's off of it when moved back and forth. now that the clutch cable is pulling tight i think all it needs is that adjustable cable.
V
v8only
2,378
22
49
Apr 14, 2004
#18
  • Apr 14, 2004
  • #18
No it shouldn't. If it grabs right off the floor, you are wayyyyy too loose. A properly adjusted clutch will grab right about half way up off the floor. If it's grabbing right off the floor, then you are too loose, which will cause difficulty engaging in gears, premature clutch wear, rolling at a stop, and eventual transmission failure. I found this all out the hard way.
However, a properly adjusted clutch pedal will sit in height right about where your brake pedal is, perhaps a little higher. If the clutch isn't engaging when you let off the clutch till around where the brake pedal is, then I would guess you are definetly adjusted too tightly, and it is likely constantly partially dis-engaging at all times. You're going to really biff up your clutch this way.
Your setup is not adjustable, since you have the oem setup. HOWEVER, pull UP on the clutch pedal with your left foot till you hear a click, then press the clutch back down. This will disengage the two plastic quadrant gears under the dash, and depressing the clutch pedal again will (in theory) re-engage the gears together at the proper place and with the proper clutch cable tension. Try this a couple of times, and if it does nothing, and you are still engaging too highly, get the adjustable setup. FYI, the best, hands down kit is a double or triple hook with a firewall adjuster and the oem cable. The steeda double, or upr triple hook is a kick ass setup (don't use the third hook with the upr setup, it's gonna mess u up, and is only there to bypass the steeda double hook patent. Myt brother and I found this out the hard way, ---chewed threw a new spec in 5100k miles)
On another, there is a big difference between your clutch, and a brake setup. Keep in mind, most brakes are made up of a semi metallic material, and easily will grind through rust on rotors without a problem. If memory serves me right, the clutch you bought is an organic clutch, and the disc material may not be strong enough to chew through that rust if its too heavy. I do think, however, that you'll be ok, it's just going to take longer to chew through it.
On a final note, you shouldn't be gassing the car that heavily during the break in period. I just learned this. During the clutch break in period, the new disc has small, uneven amounts of surface area, and therefore will contact the fresh, flat pressure plate unevenly. This can result in slippage of the clutch with overthrottle due to less material contacting the pressure plate. In your case, your flywheel is rusted, and has a very bad surface area, so not nearly as much of the clutch is grabbing.
Right now, as you are driving, and slipping, the clutch disc is likely getting glazed over, which will spell doom for it. I would stop driving immediately until you can confirm appropriate adjustment. When you do drive it, give it an extended break in period of stop and go driving before you apply ANY decent amount of throttle.
Good luck, I surely hope you don't have to tear it down again. Please keep us posted. If you have any more questions regarding adjustable clutch setups, clutch adjustments, or the such, feel free to ask anytime.
dastang2
2,020
tx
Apr 14, 2004
#19
  • Apr 14, 2004
  • #19
ok great info. i have been looking for an adjustable cable today but could not find one at the auto parts. what is the length of the stock cable. napa has 2 cables. one is 59 inches and the other is 60 inches. if i get a 60 inch, which sounds about right, do you think it will fit right and be adjusted. i got this cable from a guy on this sight somewhere but i forgot the name.
dastang2
2,020
tx
Apr 14, 2004
#20
  • Apr 14, 2004
  • #20
well i did what you said about pulling the pedal up and that fixed the slipping i think anyway. i did not get to rpad test it but now it tries to move when i have the pedal to the floor so i am sure it won't slip. i will do what i can with the cable tomorrow.
1 of 2 Next Last
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
L
2006 mustang gt has high clutch bite
  • leevikisley
  • Feb 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 22, 2026
leevikisley
L
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
