New engine problems
  • Thread starter Thread starter bandmc
  • Start date Start date May 28, 2007
1 of 2 Next Last
bandmc
29
  • May 28, 2007
I just finished putting a Ford Racing 302 into a 91 hatch. I had the exact same setup, part for part in a 90 that a drunk driver decided to take away from me. There are only 2 differences. This one is an automatic, and I now have a fuel pressure guage. The problem I am having is that the thing is a dog up until about 4 grand, then its like someone turned a swith on. It also seem if I lift the gas some from wot it will pick up a little. The previous car I had was already done when I bought it, so I am not sure if I am missing something, or what the problem is.
Any help would be greatly appreciated!
90topdown
138
Philadelphia, PA
May 29, 2007
  • May 29, 2007
Which FRPP motor did you install?
What kind of cam is in it?
What kind of torque converter? What is the stall speed??
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
May 29, 2007
  • May 29, 2007
there is a number of things that could be causing your problem. have you tried pulling the coeds and making sure everything is in proper running order? this is JRICHKER's checklist. try using it to help diagnose any issues.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 06-May-2007 to update PIP sensor information
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
J.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage. It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.[/
bandmc
29
  • May 30, 2007
K, pulled the codes. Engine not running; 23(TPS out of self test range), 24(Air temp sensor input ot of self test range). Engine running;23, 44(Air control system failure right side cylinders), 94(Thermactor air system inoperative). The TPS is the only one I recognise and will check voltage tomorrow. Not sure about the rest. Just an FYI, the car ran fine before the engine swap. Any help will be greatly appreciated!
jammer84_03
468
  • May 30, 2007
what about timing? where is that set at? how does it idle, bog when you rev it?
bandmc
29
  • May 30, 2007
15 deg advanced, idles ok, no bogging revving it up. It's actually real responsive in park. If you tap the gas in gear, it will spin a little, but if you stomp it, it bogs bad
jhonda
125
Huntersville NC
May 30, 2007
  • May 30, 2007
I would say its either your Tps sensor, or your MAF sensor
bandmc
29
  • May 31, 2007
Fixed the TPS, it was a little off. Same problem. Almost seems fuel related, but I have no idea when it comes to fuel injection. What should fuel pressure be for 30# injectors?
bandmc
29
  • May 31, 2007
Maybe some info as to what I have would help. Saw a post about adding what you have to your sig
bandmc
29
#10
  • May 31, 2007
  • #10
Ford Racing says my crate enginge needs 36 to 38 degrees total mechanical advance. So in theory, my initial setting of 15 degrees would not be nearly enough. Correct?
ShortThrow50
923
Pa
May 31, 2007
#11
  • May 31, 2007
  • #11
why in the world are you running 30 pound injectors on that (assuming its still a 302). Even still, that is way overkill especially if you dont have an adjustable fuel pressure regulator. That might be part of your problem. 19 is sufficient if you are running regular op end. 24 pounders if you have heads cam and intake
bandmc
29
#12
  • Jun 1, 2007
  • #12
30# is the suggested injector. I do have a adjustable FPR. The engine combination is fine, there is a problem I am overlooking, not a problem with the setup.
jammer84_03
468
#13
  • Jun 1, 2007
  • #13
i was just going to ask about wht injector you had....then i read the post ....30's would be to big...24s should fix it...just make sure you get the correct calibrated maf
bandmc
29
#14
  • Jun 1, 2007
  • #14
30's are NOT too big. I had the same EXACT setup in a 90 that got demolished. The ONLY difference in this car and my previous is this has an AOD where as the other was a stick, and I now have a fuel pressure guage. The combination works, there is ABSOLUTELY nothing wrong with any size, type, brand, color, shape of anything. Something is out of wack somewhere and I can't find it. I was hoping this had happened to someone, and they could tell me "oh yea, so and so sensor needs to be changed". But I guess not.
M
mattsclean90
17
#15
  • Jun 1, 2007
  • #15
Just the fact that you had the engine in a stick car before and now in an auto car could be the reason you say it is bogging. An auto car is not going to have that snap of a stick car unless it's properly set up. Most AOD's are really sluggish unless you pick up a lentech, PA, Dynamic..etc... Is the engine mechanically sound? I'm assuming it is since you had it in a car before. Just go back over all the basics like timing, fuel pressure, tps voltage.etc.. Also pull a few plugs and see if they are showing the engine is extremely rich.
As far as your total advance being around 32-38 degrees:
When you set your base timing advance you should pull the timing spout connector to disable the computer from changing the timing. Then set your initial timing, lock the distributor down and then put the spout back in. Now check your timing again and you'll see that when you gas it the timing advances to around 28-40 degrees on its own due to the computer having control over the timing.
As long as you have a properly calibrated MAF the 30lb injectors should be okay. I have never used over 24lb injectors for a mild N/A engine but I have seen a few people run 30's and the engines seemed ok. Just don't give up on the car. I have been so frustrated in the past with cars and I always have to walk away from them for a day or so and then rethink everything I could have missed. Give us some more info on the engine and we might be able to help you better.
bandmc
29
#16
  • Jun 1, 2007
  • #16
The engine and setup are not from the other car. They are however the same exact engine and setup part for part, as the first. The only difference being that this motor has the E303 cam(for auto tranny) vs the the B303(stick). The engine is a Ford Racing long block rated at 340 horse. Hydraulic roller cam; 282/282 deg, .498/498 lift, duration at .050" is 224 degrees on both intake and exhaust.
Full roller setup. 64cc Gt40 heads 1.94" intake valves and 1.54" exhaust. BBK SSI intake. BBK 255 lph fuel pump. BBK equal length shorty headers. BBK 70mm TB. 30# Ford Racing fuel injectors. Granatelli 90mm mass air flow sensor rated for 30# injectors. Msd coil. Ford racing 9mm plug wires. BBK underdrive pulleys. Smog pump eliminated. Custom 2 1/2 dual to 3" at the rear axle with H pipe. Rebuilt AOD. Can't think of anything else right now. The car ran and drove fine for several months before the motor swap. Til about 4 grand the car now has less power than before. There was a Hypertech chip installed when I bought the car(only mod) and that was taken out within the first few days of owning it. the car has been sitting for about a month now, cause no matter how much scratching my head I do, it just isn't working. I realize that an automatic will not act as a stick, but I could hop faster than this thing launches wot.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jun 1, 2007
#17
  • Jun 1, 2007
  • #17
what MAF do you have on the car ? what is the computer code ? I can tell you seriously that 30lbs injectors are not needed with that engine , I have a 306 that is probably putting down close to your 345 at the tires and I have 24lbs injectors on it and I have plenty of fuel running stock fuel pressure .
BlackBaer5.0
100
#18
  • Jun 1, 2007
  • #18
qoute from OP
That kind of sounds like your TPS sensor is off a tad .. eh? Since if you pull off the throttle a bit, then that is what the tps thinks is full throttle..
eh..?
bandmc
29
#19
  • Jun 3, 2007
  • #19
Ok, I can see this was a waste of time. And for the tenth time,NO, NO, NO, NO, the injectors are NOT too big.
cevtv
1,113
Massachusetts
Jun 3, 2007
#20
  • Jun 3, 2007
  • #20
Well, if you think you know better than everyone else, why did you even ask?
1 of 2 Next Last
  • Mindseye007
  • Aug 16, 2026
Mindseye007
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
  • brandyn200
  • Jun 20, 2026
AeroCoupe
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 4 5 6
3K
1974 - 1978 Mustang II Talk & Tech Nov 10, 2026
LILCBRA
