new engine troubles...
  • Thread starter Thread starter 1991vert
  • Start date Start date Oct 7, 2006
1991vert
1,103
Ludlow, MA
Oct 7, 2006
  • Oct 7, 2006
well i finally got the engine running and the car drives around. it's not running how it should though. for a 347 it seems to have crap for torque down low. the other night i had trouble spinning the tires in the rain on DR's!
i noticed when setting the timing before the timing light would cut out so i set it to 10 real quick and tightened it down. well the car ran like butthole. i replaced the coil and it seemed to be a little bit better and i went to check the timing again. i pulled the spout and the timing was at like 30*! so i set it back down to 10-11, but once again the timing was jumpy. it was A LOT less jumpy this time though and the light didn't cut out, but when looking at the pointer it would jump from 10* to 20* everyone once in a while and then back to 10*.
here's what i've done so far to trouble shoot:
pulled the codes and i got code 81 from KOER and code 91 from KOEO.
81 - inlet air control circuit malfuction. <- controls air at idle
91 - bank2 oxygen sensor lean. <- probably just needs replacing.
i replaced the coil which helped it out a little.
i checked the rotor/cap and the cap had corrosion on it so i took a wirebrush to it and i also did the same to the tip of the rotor.
does anyone have a clue?
1991vert
1,103
Ludlow, MA
Oct 7, 2006
  • Oct 7, 2006
bump
bob331T76
76
so cal
Oct 7, 2006
  • Oct 7, 2006
have you had it tuned yet, my 331 ran like dog poo until i got it tuned , picked up 67rwhp too!!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 7, 2006
  • Oct 7, 2006
Code 91 can be a vacuum leak or bad O2 sensor.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 7, 2006
  • Oct 7, 2006
Vacuum leak!!
1991vert
1,103
Ludlow, MA
Oct 8, 2006
  • Oct 8, 2006
it's only on bank 2 though... wouldn't it show up on both o2 sensors? im guessing bank2 = passenger side. would this lead one to believe it's spark due to the jump in timing?
1991vert
1,103
Ludlow, MA
Oct 8, 2006
  • Oct 8, 2006
i got bank1 o2 sensor lean today.
1991vert
1,103
Ludlow, MA
Oct 10, 2006
  • Oct 10, 2006
what size injectors should i go with?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 11, 2006
  • Oct 11, 2006
For a 347, I would use 30's with a matching MAF.
Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle. These ratings are for naturally aspirated engines.
Example:
19/.5 = 38, 38 x 8 = 304 HP
24/.5 = 48, 48 x 8 = 384 HP
30/.5 = 60, 60 x 8 = 480 HP
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85.
304 HP x .85 = 258 HP
385 HP x .85 = 326 HP
480 HP x .85 = 408 HP
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
See http://users.erols.com/srweiss/ to get the calculators used in these examples.
88Stang331
239
#10
  • Oct 11, 2006
  • #10
I didn't see it before...but you are deffinately a tool...you could have just multiplied by two and made it easier for us less smart people. (not gonna mention any names)
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
  • dan50
  • Jul 18, 2026
dan50
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
