  • SN95 4.6L Mustang Tech
new extreme compcams
  • Thread starter Thread starter 18x10roushes
  • Start date Start date Dec 10, 2004
18x10roushes
  • Dec 10, 2004
does any one know if these new compcams are any good ? i have a built bottom end and im currently getting my heads ported. anyones advise on the cams by the way i got an 03 gt on the bottle to.
billyfe390
573
  • Dec 10, 2004
Comps are good.
I personally have heard too many good things about VT to pass them up though. I will be going with VT stage 1's in a month or so.
18x10roushes
  • Dec 10, 2004
yea i heard bout the vt cams to but i went with the compcams instead thanks for the response
billyfe390
573
  • Dec 10, 2004
Whch grind?
18x10roushes
  • Dec 10, 2004
242 int 246 exh 550 lift on a 113 lobe
T
TNstanggurl
153
TN
Dec 10, 2004
  • Dec 10, 2004
Hey, just want to worn you about them, they sound alot like the 270s that we had( as far as lift and all). Make SURE that you will not have ptv. You may have to have valve releifs cut in your pistons. Just check everything, all numbers, and make sure. Don't want to make the same mistake we did.
nickthegenius
1,631
Elwood, IN
Dec 10, 2004
  • Dec 10, 2004
Unless you have some nice-sized dishes on your pistons, you may need to pull the pistons to have them flycut.
billyfe390
573
  • Dec 10, 2004
Make sure you Degree them in BEFORE you start the car. Also if your heads are off get some clay and check the PTV clearance.
9
98 convertable
31
tallahassee FL
Dec 10, 2004
  • Dec 10, 2004
I have a 302 stroker with ported heads and comps XE278 cams and love them. They make the same power as VT's, if not a little more. I have no piston to valve issues, but am running 21cc dished pistons. Valve reliefs wont make a difference either. PTVC occurs at the edge of the piston on mod motors, not in the middle like pushrod motors. For racing, I recomend XE278, for street, XE270. XE278 are crap below 3,000 rpm, but make huge power up top!
9
98 convertable
31
tallahassee FL
Dec 10, 2004
#10
  • Dec 10, 2004
  • #10
If you install the chains properlly, there is no need to degree the cams. I do reccomend checking the base circle on comp cams though. On some of the older cams (older than 2 years), the base circle was off. I have the XE278's, and have no PTVC problems. There is no need to have valve reliefs on mod motors. The valves will hit the edge of the piston, not the center like pushrod motors.
XE278's run great up top, but suffer below 3,000RPM. VT and Comp both make great cams, and if you look at the specs, they are very similar. It is just personal preference, thats all. Comp has been around a lot longer than VT though.
T
TNstanggurl
153
TN
Dec 10, 2004
#11
  • Dec 10, 2004
  • #11
Valve reliefs do work on mod motors, I know from personal experience. I had 270s and had ptv and then took the heads off and cut valve reliefs and everythin worked great. But either way you go just measure your clearances
9
98 convertable
31
tallahassee FL
Dec 10, 2004
#12
  • Dec 10, 2004
  • #12
well I am glad the valve reliefs worked out for you. I was told they wont work on a mod motor. Note to self: beat person that told me that!!! What year is your motor...96-98? Because if you had a 99-up motor, they should have cleared. Just curious.
billyfe390
573
#13
  • Dec 10, 2004
  • #13
Installing a aftermarket cam without degreeing it in is just stupid. You may not get any more power out of it but you definately know that you didnt slip up timing the cams also you know dam sure that the cams are dead on with the card.
You may take the chance on someone elses workmanship but for me I am not made of money and I dont feel like replacing a short block simply because I was too lazy to do some measuring.
nickthegenius
1,631
Elwood, IN
Dec 10, 2004
#14
  • Dec 10, 2004
  • #14
I've heard of people doing this, but how do you keep the cam from turning in the keyway after its been ground out to be degreed? It looks like at some point, the cam could turn inside the sprocket Or do you just have to torque the bejeezus out of it?
Fidanza is releasing adjustable sprockets that would make it much easier, though.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 11, 2004
#15
  • Dec 11, 2004
  • #15
Yes you may have to get them flycut!
white99gt
4,649
stockbridge,Ga(near atlanta)
Dec 11, 2004
#16
  • Dec 11, 2004
  • #16
If its torqued correctly it will not move.FYI-cams on the 200 cobra "R" do not have keyways because they are degreed.
Like the others said,if its a new motor check EVERYTHING..
98 convertable- the 270's have showed some PTV contact on ALL year motors.It depends on the piston maker(ford) they used..
18x10roushes
#17
  • Dec 11, 2004
  • #17
im haveing bigboyracing build me the wholr block so they know what there doing. check them out www.bigboyracing.com
cobranos
116
Antarctica-The coldest part.....
Dec 11, 2004
#18
  • Dec 11, 2004
  • #18
Ditto on the Comp XE278's.......I run them in a 306 stroker with 16cc dished pistons..........Just do not use these unless you want an extreme lopey idle and tons of power after 2500 rpm........
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
U
Midrange pods for a pillar?
  • urthecap
  • Sep 17, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All Sep 17, 2026
urthecap
U
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
