new gear use old shims?
Do not change them unless you have to in order to get correct backlash and/or contact patch. They are just spacers, they don't wear to speak of. Clean them good with brake cleaner and relube...
P.S. if you use FRPP gears the stock spacers should get ur backlash almost perfect. Don't mix the diff spacers up, mark each side!!!
i've been told the same by a master ford tech. if you use FRPP gears the old shims should still work just fine
