- Aug 21, 2006
- 10
- 0
- 0
Whats up guys, this is my first post but i have been lurking for some time now just soakin up info. This is my second fox, its an 89 gt with 3.73s, bbk equal length shorties, bassani catted x pipe, flowtech warlock mufflers, and an mgw shifter.
Now here is my problem, im getting vibrations through the shifter as my speed increases, the vibration is bad enough that around 90 ish i can no longer hold the shift knob because it vibrates too much, and the vibration translates through the cross member and exhaust and is loosening my header bolts.
yeah crazy. I have recently had new gears installed with a new trac-lok and bearings, new tires, balanced driveshaft, new u-joints, and new motor and trans mounts. I bought new axles and bearings today which will be installed soon. I just checked all bushings and suspension components and find nothin visibly wrong. What else could it be? Could the axles and bearings be the culprit of my problem?
Ive also read that some people have had this problem after a different ratio gear install and have cured it with an aluminum driveshaft. Also was curious if it could be maybe a shock thats dead or a quad shock? at this point im open to any suggestions Thanx in advance.
