i had AFRs put on a few weeks ago and have driven a couple of hundred miles since install. i noticed some oil on the ground and threw it up on a lift and can see the oil coming from the back of the heads so my seal is no good. i used the AFR recommended gaskets (fel pro 1011's). i used ARP head studs so i dont think they're the problem. i'm not sure what they were torque'd to but AFR recommends 65-70 #'s. what do you guys torque to? is it normal to have to retorque the bolts with aluminum heads?
