  • 1994 - 1995 Specific Tech
New Headlight Adjustments!?!
  • Thread starter Thread starter Caldwell
  • Start date Start date Apr 22, 2005
Caldwell
528
Ontario Canada
Apr 22, 2005
  • Apr 22, 2005
Sheit...
I just bought and installed new Cobra headlights and clear corners...
but they angle RIGHT to the ground.
I feel like i'm a night rider driving at night, I can't see anything!
They look cool mind you
On to my question, is there a way to adjust them without having to reinstall the headlights again?
I noticed both screws on the outside of the lights and the one on the inside of the lights, but I don't want to strip the screws by turning them...
any suggestions?
91LX_5L
1,943
British Columbia
Apr 22, 2005
  • Apr 22, 2005
if you take off your corners, (outside corner lights) then look on the out side of the headlight, you will notice two bolts on the top and bottomish of the headlight. those will adjust the angle slightly. tigten the bottom to bring it down I belive? top to bring it up? just play with those those are the ones.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Apr 22, 2005
  • Apr 22, 2005
Sure, you can adjust the headlights while they're in the car. You'll need to remove the corner lights to get to the outer two screws, tho.
Just turn the upper screw to pull the lights up. Make sure the plastic part that clips into the panel isn't rotating, and you'll be cool.
The inside edge of the screw on all three should not be threaded; it should be hex-shaped. You can grab that part with pliers to adjust any of the screws.
You can adjust the inner screw to adjust your headlights if they're pointing inwards or outwards. I adjusted all three so they sit flush with the corners and are pointing the right way. Good luck.
Caldwell
528
Ontario Canada
Apr 23, 2005
  • Apr 23, 2005
Oh thank god.
you guys are pros man.
I appreciate that... i was friggin NIGHT RIDER for 3 days!!
I couldn't get on stangnet cuz the server wasn't up
i was dyin! hahahah
thanks again guys.
you saved the stang.
(although the night ridin was kinda cool )
DFG 5OH
1,341
Louisville, KY
Apr 23, 2005
  • Apr 23, 2005
What i wanna do, psustroker did, was get some 6mm wingnuts, and replace the ****tyass black plastic with some wingnuts. Adjustments would be a breeze. Good Luck Caldwell
xr8d302
I bought a 27" monitor to compensate for my lack o
Apr 29, 2004
1,113
Medicine Hat, AB
Apr 24, 2005
  • Apr 24, 2005
Thanks fella's...when I installed my smoked headlights when I was on my break back in feb/march, they were facing a few different directions, i'll fix'em when i get home - IN A WEEK!
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
L
SN95 headlights - where can I buy more adjustment screws?
  • lparsons42
  • Jul 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 11, 2025
lparsons42
L
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
W
Headlights dimmer and gauges arent playing nice
  • wmfmike3
  • Aug 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 30, 2025
wmfmike3
W
