new here an hope you guys can help
82rscapri
10
in a house
i have an 82 capri rs 5.0 with a 87 mustang motor. its basically stock with just bolt-ons no head or cam work with stock distributor. i just put a newer T-5 in it started it up an drove it around the block real quick...noticed timing was off prety bad so i went back to the house an timed it. i went for maybe a 5-10 min ride an it was runnin good an pullin hard so i brought it back home to change an whatnot. when i got back outside after it sittin there for maybe 30 min tops it just wouldnt kick over. it tries to start but wont. if you have the ignition to start it will try to kick over but just wont...if you put it back to run position it will shutdown an then when it goes to accessory position the motor actually makes maybe a half a turn backwards. i have tried new coil new voltage regulator...new dura-spark ignition new starter selenoid an now i just took the starter itself out just to see if it was stuck fully engaged...but its fine. :shrug:
any ideas on what this could be???!?!
please gimme any ideas you have ...i would appreciate it alot!
is the motor turning slow like it has a dead battery or is it turning fine. you may have adjusted the timing too much and it is now fighting itself to start meaning that it is igniting the mixture too soon while the valves are still closed.
the motor turns fine when you try an start it...just wont kick over..and when the motor shuts down it kicks back half a turn fairly quick. if it was the timing how would it run good right before i had this problem....im stomped
any more ideas?
Cranks Ok but no start for carb’d cars.
Revised 31-Jul-2006
Carb'd cars require an old time approach to troubleshooting.
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw with the red wire to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B. ) Distributor PIP sensor or points & condenser
C.) No power to ignition system wiring or ignition box (if used)
D.) Bad ignition switch
E.) Bad fuse links.
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiBr...3d8016713c.jsp for 79-88 model Mustangs
http://www.autozone.com/servlet/UiBr...3d8019595a.jsp for 89-93 model Mustangs
http://www.autozone.com/servlet/UiBr...3d801ddb3c.jsp for 94-98 model Mustangs
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
4.) Pull the air cleaner and sniff for fuel vapor - look for signs of flooding. If so, then press the accelerator to the floor and crank for a while – if the engine is flooded, this will clear it out. You may want to have a jumper battery & cables handy.
5.) Electric fuel pump if you have one, is it getting power? Use a volt meter or test light to probe the wires at the pump.
Don't see any evidence of flooding? Then pump the throttle - does the accelerator pump squirt fuel? If so then you should have enough fuel to start the engine. If not look for fuel delivery problems. Check the fuel pump, and fuel filter. Remember that most carbs have a fuel inlet filter that protects the float needle valve from trash.
Next, get a can of starting fluid (ether) from your local auto parts store: costs a $1.30 or so. Then pull the air duct off at the throttle body elbow, open the throttle, and spray the ether in it. Reconnect the air duct and try to start the car. Do not try to start the car without reconnecting the air duct. If it backfires, the chance for a serious fire is increased. If the engine starts now, you have a fuel delivery problem.
6.) Fuel & ignition OK:
Firing order off: HO & 351 use a different firing order from the non HO engines.
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
Check to verify that it is indeed an HO engine. Remove the #1 & #3 spark plugs. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Slowly turn the engine until the TDC mark and the timing pointer line up. Mark TDC on the balancer with chalk or paint. Put your finger in #3 spark plug hole and crank the engine 90 degrees. You should feel pressure trying to blow past your finger. If you do not feel pressure, repeat the process again. If you feel pressure, it is a HO engine.
No pressure the second time, remove spark plug #5. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Put your finger in #5 spark plug hole and crank the engine 90 degrees. If you feel pressure now, the engine is not a HO model, no matter what it says on the engine.
Using a small carpenter or machinist square to mark the harmonic balancer off into 90 degree sections may be helpful here.
A 15/16 deep socket & breaker bar or ratchet may be used to turn the engine.
