New Nittos
on the dragstrip
So what do you recommend for the track? I was told to reduce the pressure to 15.
And do the racing radials need to be heated up with burnouts?
I'm not too good at the burnouts. I was told to stay out of the water box with treaded tires, and I still get too much wheel hop to much more than make them chirp...embarassing. I wish I knew how to sit and smoke 'em like the others do :shrug:
NT555R racing radials. Got em for my anniversary.
Hubby is my pit crew :D
I was told to 'break 'em in right' before racing, but someone else said don't worry about it. Last race the track was hot hot hot (over 100) and they hooked up nicely, but I still only got into the 13s once. I guess not bad for a stock '01 Cobra 'vert, but I want to go faster.
If you have the 555's stay out of the box and keep your tires at regular psi. Dropping them will not really do anything for you becasue a radial tire has a strong sidewall by design which will flex very little which is the intent of you dropping the pressure. It will do more damage to the tire than anything. If you have the 555R's then drop the pressure to about 15psi. Do a burnout till you see some smoke and you are good to go :nice: .
67GTA-FB429 said:
So it sounds like find my personal preference for tire pressure for street driving. I was running my Eagles at 40psi.
The 275s exacberate the 4x4 look. So I guess I am looking at lowering the car...C-springs most likely.
I would say if you run 40psi and don't have a 9.5 or 10" wide rim with the 275's you will wear out the centers before the edges. Now if you live in the mountains and blast the curves on a daily basis, then you're probably good to go. :)
67GTA-FB429 said:
So what size rim do you recommend with a 275 tire? Or is that rim recommendation for 40 psi?
Ideally a 9.5" is recommended for the 275 but they will work on a 9" you just can't run high pressures and get straight across tire wear using that size.
If you have a 275 on a 10" rim then you would have to run high pressures to keep them from wearing more on the outside edges.
