New O/R exhaust smoking?
GTFTW
51
hi guys. i had my o/r h installed today along with having some mac flowpath mufflers welded-in. im noticing that its smoking out of the tailpipes. its not a lot but its definitely noticeable in my rearview. is this normal after just having it installed?
It's a combination of burning off the manufacturing greases/oils from the new exhaust components and the fact that you got rid of the catalytic converters.
You guys just havn't smelled Ethanol. Mmmm, E85 :drool:
Anyway, yes, it is normal for your exhaust to smoke at first, both inside and out. Just as someone else said, there is grease and some oils on the outside, from both installation (greasy hands), and the manufacturing process.
ive had to switch fuel stations from my normal one because theyve started using 10% or less ethonol, and smells like s*** when it sits and idles for more then a minute. also mines SCREAMIN loud and i love every dB of it:D
If you want to know what E85 smells like before burning, take a whif of some everclear. It's just a more pure version for your body instead of your car. ;)
My 88 stang is switch to run on E85. It used to be rich enough, that I would occasionally get a strong smell of ethanol when I stomped on the gas.... ohhh, sooo great to feel that kick in the pants as boost came on and smell the ethanol. I used to worry that if I got pulled over, the cop would automatically assume I'd been drinking start the sobriety tests. Now, I've got the oxygen sensor working and the AFs are more normal, so the smell isn't so strong.
lol looks like i need to find some e85 to huff :p
As many have already stated above, it's completely normal for it to smoke immediately after install.
Mine smoked for a few days and then was fine.
im sorry forall the noob questions.....but i have 1 more lol
should the exhaust sound raspy from about 2k-3500? is the o/r h causing that or is it the 2.25" flowpaths?
guys, i seem to have a problem with the exhaust. its EXTREMELY raspy on acceleration (even taking it easy). i've had 2 people come up to me and ask if im running open headers. i ran into a guy with an 01 gt with the same h-pipe and mufflers and it isn't nearly as raspy as mine. it honestly sounds like im running open headers, its THAT raspy and loud.
what could cause this? leaks? im already getting tired of it :(
