Electrical New O2 sensor harness has no jumpers (91/93)…
  • Thread starter Thread starter afjLX
  • Start date Start date Dec 11, 2024
A
afjLX
83
20
18
DFW,TX
Dec 11, 2024
  • Dec 11, 2024
My lx 5.0 hatch had on off-road X with no o2 sensors or harness (previous owner did this) running a A9L ecm. . Main sensor connection still existed near the passenger fender. So I installed 2 new Bosch sensors and ordered a new sensor harness from LM r. This new harness does not have the jumper on the plug. It doesn’t even have a pin in one of the connector holes where this jumper would go. I verified all connections and voltages at the sensors and connected everything up. Car starts fine and all of the o2 codes disappeared. Do I need this jumper? Or just run it?
Update to this:
So I previously had code 67 (neutral safety switch error) and could not run the KEOR test to scan codes. Jumpered pin 30 to ground to clear this so I could pull codes. I left this connection tied to ground. After doing more digging, it appears the loop in the o2 harness is tied somewhere to pins 30 & 46. So my question is should I remove the ground connection on pin 30 and run the loop wire jumper at the o2 sensor harness? Is there any reason I can’t just leave pin 30 connected to ground and ignore the o2 loop?
Update 2: I went ahead and installed the jumper on the o2 harness and removed the chassis ground to pin 30 at the ecm. Code 67 never popped up as expected. So I’ll install a permanent jumper at the O2 harness and run it that way.
gkomo
now i can hopefully expect to receive the shaft
Aug 2, 2024
2,263
1,489
133
San Diego, CA
Dec 11, 2024
  • Dec 11, 2024
Did you fix code 67 or just bypass? Sorry not exactly what you’re looking for per your thread.
Reactions: afjLX
A
afjLX
83
20
18
DFW,TX
Dec 12, 2024
  • Dec 12, 2024
Well, I still have pin 30 connected straight to chassis ground which has eliminated code 67 for the neutral safety switch. I may just try to add the o2 jumper at the harness and remove the pin 30 ground connection I made and see if that does indeed eliminate code 67 as expected. I’m just wondering if it’s even necessary? Can I just leave pin 30 grounded? Does the O3 loop serve any other function? The LMR 91/93 O2 harness does not have a jumper wire on it.
gkomo
Aug 2, 2024
2,263
1,489
133
San Diego, CA
Dec 12, 2024
  • Dec 12, 2024
I’m not sure but my KOEO pulled a code 67 so I bought a new neutral sensing switch, the one that goes up on the front top of the transmission, in hopes of fixing that. Was curious if that’s what you did.
A
afjLX
83
20
18
DFW,TX
Dec 13, 2024
  • Dec 13, 2024
So I went ahead and installed the jumper on the o2 harness and removed the chassis ground to pin 30 and that did as expected. No code 67 popped up.
My ‘87 is a 4cl to V8 swap and doesn’t have the clutch pedal switches mounted. Previous owner did the swap and didn’t bother mounting them. So I’m sure the switches at the transmission are jumpered out. I do plan on installing the pedal switches and trans switche and making everything right eventually.
Reactions: General karthief and AeroCoupe
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
