new oil pan gasket leaking!
93project
549
52
38
El Paso, tx
The new motor runs very well, needs tuning to get the idle right but I just saw that the oil pan is leaking up front and in back! It's a fel pro one piece and still! Damn, NOT in the mood to pull motor again...... :mad::fuss:
question... this engine and the oil pan gasket are totally new. the car had only run about 8 mins in total. if i lift the motor with my hoist, drop the pan and reposition the gasket to sit better, would that work? or is the gasket trash after being used for a bit?
Make sure you don't wrench down on those bolts, if you squeeze the gasket out the side you have tightened them too much, even pressure. Yes, you should have used a little gasket sealer on both sides of the whole thing.
