New Problem after Head Work
  • Thread starter Thread starter 88GTAbuser
  • Start date Start date May 19, 2006
88GTAbuser
Florida
May 19, 2006
  • May 19, 2006
1988 GT 302
Original Problem: Bad Head Gasket
Work done to fix: Removed all mechcanical components down to the heads. Sent heads out for complete rebuild valves, springs ect. Cleaned and reinstalled used parts back to original locations.
New Problem: Exxcessive amount of black smoke (smells like fuel).
Items re-checked: Timing-No problem found. Codes- no codes found.
I have been working on engines for awhile but I am not very familiar with this injection system (Factory).
Things I plan to check next: Intake gasket, vaccum line arrangement, rocker and head bolt torque.
If anyone has any suggestions or ideas I would appreciate it.
FORCED2DV8
458
Grand Rapids MI
May 19, 2006
  • May 19, 2006
Check your fuel pressure, If you have a factory fuel pressure regulator it may be defective,
You may have a leaky injector, I would test those if you havent already,
Make sure the vaccum lines are hooked up preperly and all sensors are in place...
Black1987Stang
1,422
Jersey Shore
May 19, 2006
  • May 19, 2006
+1 for bad fuel pressure regulator or something with the fuel system
88GTAbuser
Florida
May 19, 2006
  • May 19, 2006
I have a few vac diagrams from the internet but if anyone else knows where I can view a few I can cross check my routing. The repair manual I bought is not that great
RaceDvr50
121
Coon Rapids
May 19, 2006
  • May 19, 2006
You did remember to put the dongle back in after timing right?
88GTAbuser
Florida
May 19, 2006
  • May 19, 2006
Which Dongle
FORCED2DV8
458
Grand Rapids MI
May 19, 2006
  • May 19, 2006
The spout connector.... pass side of engine compartment, sorry thats 95, I think yours is by the dizzy..
RaceDvr50
121
Coon Rapids
May 19, 2006
  • May 19, 2006
Yes it's by the distributor and if you didn't pull it to time the car then your problem is probably that your car is off time. You pull it, set the timing to factory 10 degrees or whatever you have chosen for your set-up and then tighten the dist. re-check and put the dongle or spout connector back in. Good to go.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 19, 2006
  • May 19, 2006
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring & vacuum lines. It is a must bookmark for any Stang owner.
http://www.veryuseful.com/mustang/tech/engine
88GTAbuser
Florida
May 19, 2006
#10
  • May 19, 2006
  • #10
Thanks for the help Guys Im really glad I stumbled across this site. I have owned pretty much ford my whole life but It was usally older stuff. With out all this fancy electronics. I bought the Mustang recently and have been having to clean up alot of the previous owners hack jobs. I hope this helps.
baskin
152
May 19, 2006
#11
  • May 19, 2006
  • #11
Check to see that the engine coolant sensor got reconnected, if it didn't, the ecu will default to reading the cold fuel tables in lieu of the o2 sensors
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
