  • SN95 4.6L Mustang Tech
New rear end
  • Thread starter Thread starter 02TruBlueGt
  • Start date Start date Jan 30, 2007
02TruBlueGt
  • Jan 30, 2007
Ok so im replacing my gears and doing the install myself. I am experienced and have taken classes on this so im not worried. My question is i want to bullit proof my rear so i can really launch on some slicks. What do you guys use as far as lsd goes? I plan on some moser 31 spline axles. What rear unit is best in you guys honest opinion??
thanx for the help :SNSign:
BennyBlown2v
1,233
Carmel, INdiana
Jan 30, 2007
  • Jan 30, 2007
Ford Trak-loc diff, they are cheap and easy to rebuild. If all you're doing is going straight, go with a spool. Also weld the upper and lower torque boxes at the seams, and weld the axle tubes to the center section.
the98stang
2,408
Clovis, CA
Jan 31, 2007
  • Jan 31, 2007
^agreed
Trac-Loc diff w/ 31 spline axles. Seal the pumpkin with a nice cover.
02TruBlueGt
  • Jan 31, 2007
Well i would go with a nice spool , but i plan on doing some auto crossing. I was doing some research and found a detroit Truetrac diff to be the best anyone got any exerience with these??
RandyStinchcomb
1,159
Randallstown, Md
Jan 31, 2007
  • Jan 31, 2007
get a good quality rear end girdle, one wth drain and fill holes like the one sold by T/A
02TruBlueGt
  • Jan 31, 2007
i already have a fms girdle with fill and drain plugs in mind. I plan on running slicks and with 4.10s i have had to many friends snap axles and blow the trac loc in the diff. Id rather build it up while im in there you guys know.
So the setup im thinking is
-Detroit Truetrac Diff
-Moser 31 spline axles
-FMS Axle girdle cover
-All new bearings etc etc
-Nicer stronger wheel studs (suggestions/size??)
I also might be spraying a 100 shot soon so i really dont wanna blow it up haha
BennyBlown2v
1,233
Carmel, INdiana
Jan 31, 2007
  • Jan 31, 2007
You know guys who have snapped 31 spline Mosers, and blown up 31 spline diffs? Dang... Trac-lok is easy and cheap to rebuild if you ever kill it. It's way more cost effective than a trutrac - not that that is a bad option if you wanna shell out the $430+ for one. $80 for a used 31 spline explorer diff, $55 for carbon fiber clutch trac-lok rebuild... $135 vs. $430+, trac-lok is the better choice imo.
Moroso makes wheels studs, Motive has a good bearing kit.
02TruBlueGt
  • Jan 31, 2007
Nooo i know guys who have blown up the stock diff and axles. Just using 4.10s and slicks, and since ill be running 4.10s slicks and a 100 shot or blower havent decided I really dont feel like breaking crap. So since it will be out anyhow might as well built it and i had planned on the motive bearing kit.
jivepepper
776
Under a Sombrero. in WV.
Jan 31, 2007
  • Jan 31, 2007
Having this installed next wednsday:
205 forged usa alloy 31 spline axles with new axle bearings, seals, and studs
140 rebuilt 31 spline explorer tloc including rebuild kit, rebuilt myself with extra clutches kit came with modifier
80 bearing kit with shims and seals
3.73 gears used for 60 bucks
24 fluids
507
350 labor install and welding tubes and boxes.
857
BennyBlown2v said:
$55 for carbon fiber clutch.
I've look everywhere and can't find the carbon fiber for less than 90 or so. The regular kit was 45 before shipping.
02TruBlueGt
#10
  • Jan 31, 2007
  • #10
Well now im paying for a lawyer lol..... stupid cops. Long story, but it could take a lil while longer to get this stuff installed. Nice setup jivepepper see im installing all myself so i get to save the 350 labor cost. Hence ill have more money for the truetrac. If i was not doing this myself i would just get and rebuild the explorer diff.
BennyBlown2v
1,233
Carmel, INdiana
Jan 31, 2007
#11
  • Jan 31, 2007
  • #11
24 fluids
507
857
That's the same setup I have going in, cept i went with new gears - and I have free labor heh. I haven't bought the rebuild kit yet, but I was told by a friend of mine who works in the parts department at a dealer that it was $55 with his discount.
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
Hi. I'm new. 98 Cobra Bent Axle.
  • sbk93036
  • Mar 28, 2026
SN95 4.6L Mustang Tech Oct 5, 2026
Mustang5L5
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
