New Setup...Trans Question
  • Thread starter Thread starter 351carlo
  • Start date Start date Oct 26, 2004
351carlo
267
Philadelphia
Oct 26, 2004
  • Oct 26, 2004
Ok guys, the new setup is listed below:
351 Cleveland with 2 V heads
.030 over
2.055 Intake / 1.71 Exhaust Manley Swirled Stainless Valve
.519/.519 lift cam 270H Comp Cams with matching springs
3A valve job
Erson Roller Rockers riding on a Crane Cam Conversion kit
Hardened Pushrods
Speed Pro Hypereutectic 9.5:1 Compression Pistons
Canton 7qt oil pan w/ Crank scraper
1 3/4" Hooker Comp Headers
2.5'' dual exhaust, awaiting H-Pipe
Edelbrock Performer intake
Road Demon 625 carb
Pertronix Ignitor II Ignition
Going for 375 at the crank. Problem is my transmission, an FMX, was just rebuilt new, and a B&M shiftkit installed, stage II Street/Strip setting. A slightly higher than stock converter installed, no more than 2500 RPMs. I know the FMX is the heavy beast, and more parasitic than others, so what type of loss is typical from them. Going from 375 at the crank, what type of power should I expect to see at the wheels?
I appreciate the help guys.
HistoricMustang
2,359
Confederate States of America
Oct 27, 2004
  • Oct 27, 2004
I remember reading somewhere that as a general rule, it is a 50 to 75 horsepower drop to the rear wheels. Someone correct if I am wrong.
If you are just dying to know spend a few bucks and her put on a dyno.
HistoricMustang
www.historicmustang.com
302 coupe
1,952
Macon, Ga.
Oct 27, 2004
  • Oct 27, 2004
I think the FMX sits right between the C4 and the C6 as far as parasitic loss is concerned. I wouldn't worry about it....
As far as power, I'd go with a bigger carb but for street driving you won't notice much difference. I'd say 330 at the fly, 270ish at the wheels. 375hp is asking a lot for the 2V heads and 9.5:1 compression.....
351carlo
267
Philadelphia
Oct 27, 2004
  • Oct 27, 2004
I'm going with a 750 Holley once I get it rebuilt. Just sitting here waiting for me to rebuild it.
My machinist says 375 is conservative with the way the heads sit right now...not sure why, but he's pretty confident on 375+. I guess we'll find out soon enough.
302 coupe
1,952
Macon, Ga.
Oct 27, 2004
  • Oct 27, 2004
do you have any details on the heads, besides them being 2V castings? Open or closed chamber, any port work, etc....
This is just my opinion, but 2V heads are for stock engines. If you want performance, the 4V heads are practically a must have. I've driven a few cleveland powered fords, and rebuilt one 2V and also a 4V. The 2V was built to be a street engine, it got a mild cam, 9.5:1 comp., performer intake, a 600 holley, and good duals. The engine ran well, but lacked power. The 4V had closed chamber heads, stock intake manifold, 750 double pumper, 10.5:1 comp., and a crane cam with .519/.524 lift and 230ish dur@ .050. The 4V was actually a pretty mild build, but simply annihilated the 2V in power. It had good street manners and ran well on pump gas too. It made me a believer in the 4V heads, and trust me they don't lack low end power at all. I think the guys that started that rumor are the guys shipping in aussie 2V heads.....
351carlo
267
Philadelphia
Oct 27, 2004
  • Oct 27, 2004
It's just a set of stock 2v heads which are given some better valves. They're topped off with the valves mentioned above (2.055/1.71). The ports are still abnormally large for a motor of it's size. I'm running a .519/.519 cam. I would have preferred to run some 10.5:1 Forged pistons, but budget was tight, and decided against it. Running what is supposed to be the 9.5:1 hyper's required milling down the head to achieve the proper CR with my open chambers.
R
Random Question on EFI setup
  • Rcdgl
  • Apr 10, 2019
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2019
a91what
New Member: 1978 M II Mach I
  • 351MooseStang
  • May 24, 2019
3K
1974 - 1978 Mustang II Talk & Tech May 30, 2019
351MooseStang
Fox New To Mustangs And Have A Few Questions
  • Czar_Tyler
  • Nov 20, 2013
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 22, 2013
Blown88GT
C
  • Locked
complete 393w setup airfilter to oilpan puleys to flywheel
  • casey Brittenham
  • Dec 7, 2011
  • Engine and Power Adder
2K
Engine and Power Adder Mar 14, 2012
lxboy
L
C
  • Locked
complete 393w setup from air filter to oil pan pulleys to flywheel $2750
  • casey Brittenham
  • Dec 7, 2011
  • Engine and Power Adder Parts
Engine and Power Adder Parts Dec 20, 2011
martinez289
