New starter doesn't work. Help
impulse001
84
New Jersey
So I installed a new starter today, I chose a mini- high torque. I tested it before installing it, and it worked great. After installing, when I start the car, it sounds like the gears may not be grabbing. I just hear louch clanking coming from the starter. Is there a way I am supposed to line up the gear in the engine to the geat in the starter? It bolted up fine so I figured the gears were good?
Fett
766
Was it specifically for a 5.0, or is it one of those with multiple mounting holes for different engines?
Check the instructions or check online for your brand, you might have to shim the starter.
