New TKO 600 Price quote inside, opinions...
TT91
1,536
43
Paramus, NJ
members.rankmyride.com
This is tremecs new tko 3550 series trans. 600 hp 600 lbs
I just received my quote for the tko 600, with everything included for a easy swap...here it is
TOTAL $2,298.00
Neutral Safety Switch Plug $8
McLeod Steel bellhousing $279
Speedo driven gear (4.11, 255-55-16) $15
Weber Dual Friction Clutch disc (26 spline) $150
Reverse Light switch $8
GM Synchromesh trans fluid $10
Adjustable crossmember $59
TKO HD Slip Yoke (1330 series) $69
TKO-600 5sp, 600 ft/lb (.64 5th) $1676.00
What u guys think, worth it? too much money? go somewhere else?
I know you can get the Mcleod for about $10 cheaper. The trannies come with yokes, at least the old TKOs did. Id also check into a better clutch disc for your motor, like a spec stage 3. You also dont *need* that adjustable x-member. Just grind the tac welds off, slide it back, and re-tack them
You're current spec stage III disc wont work, need a fine spline disc. I just upgraded to the stageIII from my stageII, same pressure plate. Cost $150 shipped for just the disc from spec. They told me it will hold 680ft lbs of torque. I would go for it.
mike.
Just got off the phone....ordering parts...
NEW X2C TKO 500 V.1 trans rated at 850hp....$1999
Mcleod disc-rated 850..... $200 sumthin
Mcleod scattershield.... $189
Auburn Pro 31 spine posi $389
AND
Baer M2300 Killer, 31 spline, 5 lug, disc brakes..$1895
Everyone loves new parts...but i have that sickening feeling in my stomache for some reason..
X2C was outstanding over the phone, i spoke with Mark, who was very helpful and intelligent. TWO thumbs up
Mcleod twin disc-rated 850..... $200 sumthin
AND
Damn, congrats on the new parts. Let me say you go all out.:worship::nice:
Dave
oh, ok. Ive got the same one, at least i think it is.
If you drive the car alot though, or rather plan too, the street twin would be a great clutch setup. Really soft pedal and will hold all the power you can throw at it.
Man!!!!!!!!!!!!! I think the sickening feeling is due to the fact you were originally looking to get a tranny/scattershield set up and wound up with 2k in other sheot :rlaugh: That rocks though, I gotta do something about brakes, I have a feeling after trying to slow down from a good run on the new motor with stock brakes, i'll scare myself enough to get some :p
