Welcome to Stangnet...
Not all of us know how to fix everything, but some of us know how to fix some things
with excellence!
Some things to consider from someone who has been driving and fixing 5.0 Mustangs for 20+ years...
If you are in California or some other state with strict emissions laws, part of the deal should be that the owner takes the car and has it emissions tested. If it passes, you buy the car and pay for the emissions test cost, if any. If it does not pass, walk away from the deal. For a mechanically inexperienced owner, emissions related problems can be difficult and expensive to fix.
Keep in mind that states with strict emissions laws may make the go faster goals more difficult to reach. Some parts are OK to replace with aftermarket parts and others aren't. Check carefully before you get out your wallet and buy something you can't use in the area where you live.
If you want to do the fix up & power up thing, make sure that you have some other
form of reliable daily driver. That way the stang can sit while your wallet and hands
take a rest from the last project that didn't quite get finished on that 3 day weekend.
Things always cost more and take longer the first time you do them. Having some
other working vehicle makes life easier since it isn't the big crush to get it running
for the Monday morning drive to work or class.
Plan on spending some money on tools it you don't already have them. The stang
has both metric and American fasteners, so you really need two sets of wrenches.
A timing light, digital voltmeter, vacuum gauge, compression tester, fuel pressure
test gauge and fuel line coupler tools are some of the test & tuning tools you'll need.
Visit the pawn shops and sometimes you can find a deal on tools & test equipment
if you stick to well known name brands.
A sheltered work area is almost a must, someplace that you can leave the car in
pieces without upsetting anyone. Some guys here have changed a transmission in
the parking lot of their apartment in a rainstorm, but they will tell you it wasn't fun.
Depending on where you live, a warm dry garage is a nice place to do the winter
projects that stangs tend to become.
EFI (Electronic Fuel Injection) Computer - every stang after 85 has or had one:
don't let it intimidate you. The computer based EFI systems are not hard to fix
and most of the time they tell you what's wrong with the engine. Here's a book
that will get you started with how the Ford electronic engine control or "computer" works.
Ford Fuel Injection & Electronic Engine Control 1988-1993 by James Probst:
ISBN 0-8376-0301-3.
It's about $35-$45 from Borders.com see
http://www.amazon.com/ . Select
books and then select search. Use the ISBN number (without dashes or spaces)
to do a search
Use the ISBN number and your local library can get you a loaner copy for free.
Only thing is you are limited to keeping the book for two weeks. It is very good,
and I found it to be very helpful.
For lots of great ideas and tech notes on upgrades and repairs, be sure to check
out
http://forums.stangnet.com/showthread.php?t=643651 “Useful Technical Thread Index” sticky at the top of the 5.0 Tech forum.
Things that break often:
T5 5 speed manual transmission (syncros go bad, mostly 3rd gear)
TFI Module (Thin Film Ignition module - mounts on the distributor)
Electric door locks (see the link in my sig for a cheap & easy fix)
O2 sensors(oxygen sensors) They are good for about 60,000 miles and start to go
down hill after that.
TPS Sensor (Throttle Position Sensor) causes flaky problems with idle & acceleration.
Fog lights They overheat the wiring and cause the headlights to flicker. The fix is
cheap and simple if you can do electrical stuff.
Harmonic Balancer – they separate between the hub and outer ring. A harmonic
balancer puller is a must have to change it. You can rent or borrow a puller from
most of the larger auto parts stores.
Things that are very durable:
Engine - as long as it hasn't been abused, it will run good for 150,000-200,000
miles without an overhaul
Rear axle other than an occasional case of worn clutches in the traction lock,
they almost never have problems.
Computer - believe it or not, the computers seldom have problems of their own.
Most of the problems are with the sensors and the wiring.
Suspension – the front and rear suspension has very few problems if the car hasn’t
been wrecked or seen a lot of drag strip runs. The drag strip runs tend to distort and
tear the mount points for the rear axle control arms. Revving the engine up to 4000
RPM and dumping the clutch with slicks or drag radials tends to break things.
Things that don’t break often but are hard to fix:
Water pump mount bolts – they corrode and shear off when you try to change the
water pump.
Rear oil seal on the engine – lots of parts to remove to get to a $20 seal.
Power steering pump – the pumps are noisy and the pulley requires some special
tools to remove and install. If you have the tools, they are easy to do. Again, the
larger auto parts stores will rent or loan the tools for the pulley.
Power Steering rack - it is hard to get the toe in set so that you can drive the car
to the shop to get it properly aligned.
Starter – the top bolt is hard to get a socket on if you don’t have the right combination
of socket, universal joint and extensions.
Everything considered, 5.0 Mustangs are not hard to work on. They just require
some patience and though before you get started.
Still want more performance and on a budget? do the junkyard upgrade...
Gears - 87-88 T-Bird Turbo Coupe rear axle - disc brakes and 3.55 or 3.73 gears in one package for $125-$300. Add another $100-$200 or so to complete the brake upgrade.
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a flange adapter to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes. *1 *2
95-97 Ford Explorer intake manifold & throttle body $150-$300. The intake manifold flows 220 CFM +, much better than stock. Throttle body is 65 MM, bigger than the 60 MM on stock stangs. I got a 96 with EGR passages that match the stock setup, so my smog gear works just like factory. You’ll need a 65 MM EGR spacer & new gaskets for $65-$90 so you have a place to mount the EGR & throttle linkage.
3G alternator from 94-95 Mustangs or other Ford. $20-$120. A must have to make the electrical system work like it should or if you have an electric fan. You’ll need a 4 gauge power wire and a 125-135 amp fuse to go with it about $15- $30.
Lincoln MK VIII electric fan -$40-$160. Free up some HP by not having to drive the stock fan. The 3G alternator upgrade is a must have prerequisite before you do the MK VIII fan. You won’t have enough electrical power if you don’t do the 3G upgrade.
Aluminum driveshaft: (courtesy of shawn13) It needs to be from a 92-93-94 Aerostar AWD. It measures 45 ½” center of the front U-joint to center of the rear U-joint. You will need the U-joint, part #PUJ353 from NAPA. The Canadian NAPA pat number is 1-0134BF. It should bolt right up after the U-joint swap.
Note: This driveshaft is not an exact duplicate of the Ford Racing part. It is 3” in diameter while the Ford Racing part is 3.5” in diameter. There is no guarantee that the balance will be any better than the stock part.
Use a piece of string and wrap it around the driveshaft. Make a mark on the string where the ends overlap. Measure the length of the string:
On the 3" AeroStar driveshaft the string will be 9.42" or about 9 7/16" long.
On the Ford Racing 3.5" driveshaft the string will be 10.99" or about 11" long
*1.) Metal flange adapter
http://www.kustomz.com/components.html Buy the TR70 for $40. Or spend some time on eBay looking for one that may fit.
*2.) MAF & sensor interchange
The 94-95 Mustang 5.0 MAF & sensor is also found on:
1995-94 Mustang 3.8L F2VF-12B579-A2A,
1994-92 Crown Victoria 4.6L F2VF-12B579-A2A,
1995-94 Mustang, Mustang Cobra 5.0L F2VF-12B579-A2A,
1994-92 Town Car 4.6L F2VF-12B579-A2A,
1994-92 Grand Marquis 4.6L F2VF-12B579-A2A,
Evidently the –A1A, -A2A, AA, etc. on the end of the part number is a minor variant that did not change the operating specs. You should be able to ignore it and have everything work good.
