  • 2005 - 2009 Specific Tech
new to stangs and gears
  • Thread starter Thread starter youknowmeehan
  • Start date Start date Aug 31, 2007
Y
youknowmeehan
  • Aug 31, 2007
if i buy 4:10 gears for an automatic will i need any other parts and how will this make my stang perform?
speed1972
891
Denver, CO - Buckley AFB
Aug 31, 2007
  • Aug 31, 2007
The search function will yield a wealth of information.
As far as the gears, I assume you have not done this before. Pick up a set of FRPP gears...worth the extra couple dollars then find a reputable shop and have them perform the install. You can pick up a basic install kit or have the shop do it. Either way, it'll probably run about the same cost. You will also need a tuner to program for the gear swap. The car will not run properly otherwise. You can get either a Diablo Sport Predator or a SCT Xcal2; they both run $400.
Hope that helps...
LB
kooldawg6
mine works really well and can take a fair amount
Aug 31, 2006
1,679
Central VA
Aug 31, 2007
  • Aug 31, 2007
Hope that helps...
LB
My install cost just over $500 including parts at a local speed shop pretty much dedicated to Ford(mostly Mustangs and Lightnings)vehicles. The tuner, be it from Brenspeed(where I purchased mine)or Bamachips with their custom tunes loaded will allow you to not only adjust for the new gear(and numerous other options) but will make your car a beast compared to stock.
anthony05gt
1,262
Maryland
Aug 31, 2007
  • Aug 31, 2007
If you have say 2 thousand or less miles on the car an install kit is not necessary for a gear change.
kooldawg6
Aug 31, 2006
1,679
Central VA
Aug 31, 2007
  • Aug 31, 2007
I had just over 13K on mine and they didn't use a kit. At that time, the guy had done over 30 of the '05+ with no problems(I definitely was asking questions ). They are a sponsor of the local Mustang club so I feel confident with their knowledge.
speed1972
891
Aug 31, 2007
  • Aug 31, 2007
Probably the only thing that is a must to replace is the crush sleeve.
I only suggested a basic install kit because of crush sleeve, marking compound, shims, sealer, lube, etc depending on the kit.
LB
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
