New to Stangs,.. but..
ts1lmayb said:
hmmm. different intake and stuff :bang: the search function works great noob
:rolleyes:
to answer your question, the main difference is the heads, cams & intake. 99 is when they started with PI - 'power improved' heads. that is the main difference but there are other subtle differences, but that's the big one that makes the big difference :nice:
Bubba Z. said:
The main difference is horsepower (225 vs 260) due to the heads/intake manifold/cams. As someone said, the 99+ GTs were power improved (PI). You can slap PI components onto a 96-98 GT as many have done.
--Bubba Z.
as this post said you can install the PI 99-04 heads,cams and intake onto a 96-98 motor. the compression is higher when you do the headswap on a 96-98 so you will make a little more power than a 99+ car. if you want too know more., do a search on PI headswaps it's a very straight forward swap
BTW if you are going to use a aftermarket head on a headswaped 96-98 i highly recomend checking PTV clearance ( piston to valve) have the new cams degreeed and check the PTV yourself ( or your builder) do not go by what anybody says will work.
