A fox body tranny wont work unless you change the input shaft an the bell housing. The SN95 tranny’s are longer to put the shifter in the proper place
Off the top of my head, youll need the pedal assembly, clutch cable, flywheel, pressure plate, clutch, transmission, shifter parts, and youll need to plug up/ remove the tranny cooler lines. You’ll also need a new ECU or a chip for you existing one so its not pulling timing when it thinks it needs to shift.
