  • SN95 4.6L Mustang Tech
New Trick Flow plenum
  • Thread starter Thread starter 88xsquad
  • Start date Start date Feb 23, 2004
88xsquad
25
Franklin, KY
Feb 23, 2004
  • Feb 23, 2004
Has anybody used the new Trick Flow plenum? I seen it in my Summit catalog the other day and was wondering if it would be a worthwhile bolt-on if it was paired up with a 70-75mm t-body for my car. I've heard the C&L plenum mentioned here, but not the Trick Flow plenum. Thanks all!
313Stang
89
Detroit
Feb 23, 2004
  • Feb 23, 2004
I installed the Trickflow model on my car along with the BBK 70mm TB.. Install was very easy of course.. A couple of notes though.. the hose that comes into the rear of the plenum will need to me slightly modified in order to fit onto the fitting that is provided with the plenum. Also the bracket that holds the throttle cable, cruise control cable will no longer rest on top of the plenum as it did with the stock unit. As far as gains I can feel a very slight SOTP measurement.
T
Too Slow
209
Houston, TX
Feb 23, 2004
  • Feb 23, 2004
where did you get it from and for how much?
Firemanz
Only you can prevent Forest Fires!
4,105
San Antonio, TX
Feb 23, 2004
  • Feb 23, 2004
Anyone have pics of it? Is it black, polished.............?
88xsquad
25
Franklin, KY
Feb 23, 2004
  • Feb 23, 2004
You can see it in the newest Summit catalog, in the Mustang section. The catalog sez you can get it black, coated or plain. Will you get the same results on a 98 GT as you would on a 99 GT?
88xsquad
25
Franklin, KY
Feb 23, 2004
  • Feb 23, 2004
Sorry 313, I made a typo. Anyway, do you think I would get the same results on my 99GT as you got on your '96?
313Stang
89
Detroit
Feb 24, 2004
  • Feb 24, 2004
I would guess to say you'd most likely get better gains because of your intake manifold(PI). I got mine at Ramchargers and it was like $210 or so...
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
R
New Member, needs help with built '04 engine
  • rollo19
  • Aug 6, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 6, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
SOLD Trick Flow R-Series Upper Manifold - 75mm, Black, New in Box
  • AeroCoupe
  • Feb 18, 2025
Engine and Power Adder Jun 28, 2025
AeroCoupe
