  • SN95 4.6L Mustang Tech
newbe mustang Q
  • Thread starter Thread starter 4.6boy
  • Start date Start date Jan 17, 2008
4.6boy
187
  • Jan 17, 2008
i got a 02 gt and thre is oil around my pcv vavle i even replaced it wih a new one and it still is leaking is this normal its not a lot just some drops?? also some times thre is a knock/ticking sound tat usly gose away can this be from useing 93 super gas>>
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
Jan 17, 2008
  • Jan 17, 2008
The pcv is known for sucking up some oil. Some people run a catch can so that the oil doesn't get into the intake. You can search on here for that.
Using a higher octane shouldn't cause ticking. As long as the sound goes away, I wouldn't worry too much. Something in the valvetrain may just be sticking and it goes away as the engine heats up.
Welcome to SN
4.6boy
187
  • Jan 17, 2008
thanks also i never had a v8 car before but is it normal to here a whinning nosie when u exslerat (its not blown)
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
Jan 17, 2008
  • Jan 17, 2008
The wining is most likely the serpentine belt. As long as it's not squealing
RandyStinchcomb
1,159
Randallstown, Md
Jan 18, 2008
  • Jan 18, 2008
check the hose going from the PCV valve to the plenum for hole(s) or cracks and did you get an oem Ford PCV valve? aftermarket ones do not work well on Fords.......
4.6boy
187
  • Jan 18, 2008
its a motorcraft one it didnt come with the elbow so i am just using some hose also were would i find that elbow??
eliteJAE
Stanford University
Jan 19, 2008
  • Jan 19, 2008
the wining could be the belt, could be your radio not grounded properly, OR when i removed my intake silencer it began to make a cool sucking/whining noise when accelerating
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jan 19, 2008
  • Jan 19, 2008
Why are you running 93 octane?
The GT was made for 87 octane. It will make the most power with it. Running 93 is only wasting your money.
Does the whine sound like it comes from the transmission or shifter area?
eliteJAE
Stanford University
Jan 19, 2008
  • Jan 19, 2008
are you serious?????? i use 91, and afraid to use 87 cuz of knocking or power loss, but im guessing im wrong on this. is it really better to use 87? sorry for taking it off topic. i know it was designed to perform with 87, but mines got its miles on it and its had to be torn down before for head issues, i thought running 91 would compensate for some of the wear and tear.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jan 19, 2008
#10
  • Jan 19, 2008
  • #10
Try a tank of 87 octane. If you get on it and expereince some detonation (pinging) then try for 89 octane and see if it does it there.
91 is just a waste of money. Our engines are low compression and do not have a power adder so there is no need for high octane.
RandyStinchcomb
1,159
Randallstown, Md
Jan 21, 2008
#11
  • Jan 21, 2008
  • #11
that elbow could be the problem as they are prone to leaks, I'd get a whole new hose n' elbow from FoMoCo as it seems to-be a fairly common problem wth them cracking and leaking.....
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Jan 21, 2008
#12
  • Jan 21, 2008
  • #12
Did you replace the rubber groumet around it? Mine was leaking from there. they do go bad after while
eliteJAE
Stanford University
Jan 21, 2008
#13
  • Jan 21, 2008
  • #13
good to know moneys tight, and 3.40/gal. with 91 vs. 2.80/gal with 87 is gonna save me ALOT lol
4.6boy
187
#14
  • Jan 22, 2008
  • #14
i replaced the hose and now it doesnt leak any more. the whin is diffent come from the front of the car and is only in first gear. i use 91 casue its a cleaner fuel 87 sucks makes it sound like a diesel
4.6boy
187
#15
  • Jan 22, 2008
  • #15
also the trainy has a little dirip on the rear end side but the rear seal is good??
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jan 22, 2008
#16
  • Jan 22, 2008
  • #16
Then the rear seal is leaking
4.6boy
187
#17
  • Jan 23, 2008
  • #17
its not the rear seal casue its dry by the rear seal its just a drop right after the trainy grossmenber
RandyStinchcomb
1,159
Randallstown, Md
Jan 24, 2008
#18
  • Jan 24, 2008
  • #18
then its the trans output shaft seal, could be the beginings of something major if left un-checked.....
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jan 24, 2008
#19
  • Jan 24, 2008
  • #19
Transmission rear seal...not engine rear seal
  • Gulftown980x
  • Jul 29, 2026
squeak93
G
  • Poll Poll
I got a free Mustang from Grandma
  • GrannysMustang
  • Mar 4, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 6, 2026
Realmongo
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
