  • 1994 - 1995 Specific Tech
newbie egr question
  • Thread starter Thread starter BlackVert
  • Start date Start date Jan 2, 2006
BlackVert
5,589
9
98
Bethesda, MD
Jan 2, 2006
  • Jan 2, 2006
what does the vacuum line on the egr go to, the intake?
i just noticed that i didn't connect mine to anything and i don't have any unconnected vacuum tubes ...
legalize420
1,541
South Florida
Jan 2, 2006
  • Jan 2, 2006
legalize420
1,541
South Florida
Jan 2, 2006
  • Jan 2, 2006
the red and green lines go from the intake and the egr to the fender, along with the lines for the smog pump. not sure what the piece in the fender is called
legalize420
1,541
South Florida
Jan 2, 2006
  • Jan 2, 2006
and you need to get them
HISSIN50
34
129
Jan 2, 2006
  • Jan 2, 2006
Seems to me that the vac line to the EGR snakes under the TB and runs down the pass valve cover. It then exits stage left and heads for the inner fender on the pass side (where the charcoal cannister, etc is). The line should go to the EVR, which is a solenoid that controls when the EGR gets its vac signal (during cruise conditions).
The line around the EGR valve is hard plastic and gets brittle (dont ask how I know - mine is patched together).
Not sure if that helps or not but.......
legalize420
1,541
South Florida
Jan 2, 2006
  • Jan 2, 2006
do you have a check engine light
edit, just noticed tweecer
BlackVert
5,589
9
98
Bethesda, MD
Jan 2, 2006
  • Jan 2, 2006
evr ... do you mean that little cylindrical thing up near the firewall on the passenger side with the rubber around it that has a tee on top where one side goes into the fender to a box near the door and has the electrical connector on the bottom? i'm pretty sure that is the one you mean.
so the other side of that tee goes to the egr valve? wow, i have it hooked to the vacuum side of the blower ... oops! that might explain the high idle ...
gee, i better take a pic of my vacuum lines for you guys to tell me what else i have wrong ...
HISSIN50
34
129
Jan 3, 2006
  • Jan 3, 2006
Nope, it seems to me that thing you are talking about is the purge solenoid. It has a line running under the upper intake to a port, where it infuses vapor from the charcoal cannister (which is in the pass fender). This is all part of the EVAP system, not EGR.
I would have to get out the factory manual to find the EVR (EGR vacuum regulator). I did not see it in Haynes the last time I was farting around with my EGR stuff.
BlackVert
5,589
9
98
Bethesda, MD
Jan 3, 2006
  • Jan 3, 2006
ok i think i'm on the same page with you now. the egr vac port goes to one of the three hard tubes that all come together near the alternator, right? i think the tubes have different colors ... which tube is it?
i plumbed two of the tubes together to the vacuum side of the intake. that is where i made my mistake.
ES Stangin
132
Erie, Pa
Jan 3, 2006
#10
  • Jan 3, 2006
  • #10
On my car the red line went to the intake, but Im not sure which line went to the EGR
BlackVert
5,589
9
98
Bethesda, MD
Jan 3, 2006
#11
  • Jan 3, 2006
  • #11
i may be able to figure it out now due to process of elimination. not sure tho because i'm at work and the car is still sitting in the driveway at home ...
87_GT
179
tinley park, illinois
Jan 3, 2006
#12
  • Jan 3, 2006
  • #12
a little off topic, but my hard green line is cracked i think, and i was wondering if that was something i could buy at napa, or something i had to order online. any
info. appreciated. thanks
BlackVert
5,589
9
98
Bethesda, MD
Jan 3, 2006
#13
  • Jan 3, 2006
  • #13
i would think you could get it at any auto parts store.
HISSIN50
34
129
Jan 3, 2006
#14
  • Jan 3, 2006
  • #14
Chris, you are getting some good help. I could not tell ya off the top of my head which color lines are for what. Others will though.
87GT, you can buy generic runs of the hard plastic line at the parts store. I broke the line to my EGR right at the top where it connects, so I just used a small piece of vac line as a splice for now. At some point I will redo all of those brittle plastic lines.
Good luck.
bill302
2,131
alabama,gadsden
Jan 3, 2006
#15
  • Jan 3, 2006
  • #15
o.k. you have 3 hoses exiting the intake tree between egr valve and fuel pressure regulator.
1 the large black hose exits runs down firewall to drivers side into the vacuume distribution box.
2 small black hose plugs into the fuel pressure regulator.
3 red plastic hose into fenderwell into egr vacuum regulator solenoid.
then a green plastic line exits the egr vacuum regulator solenoid then out of fenderwall to the egr valve.
the red and green plastic lines run to and from egr vacuum regulator solenoid to egr and vacuum tree, side by side with a connector at the airb (air injection bypass valve) valve where a white line exits connector and plugs into airb valve.
BlackVert
5,589
9
98
Bethesda, MD
Jan 5, 2006
#16
  • Jan 5, 2006
  • #16
good, info, but im having a hard time visualizing it. anyone have a picture?
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
