i went to check my oil because my car started suddenly lurching and behaving quite spastic and i go to grab my dipstick and the entire dipstick assembly came out am i screwed ? somebody please help me out here
no your not screwed you just need to reinsert it into the hole in the block but first clean the bottom up to and around the bevel at the bottom and apply some sealantreinsert it into the mounting hole in the block and tap the bevet until seated i used an adjustable wrench tightened it to the diameter of the tube above the bevel and tapped down on the tube bevel until it was seated.don't forget to apply sealant this will seal and help hold tube in place.
