Next mod, few questions
03silverstang
123
Thinking about getting the Accufab Plenum, Accufab TB and True-Flow Inlet Pipe from rpmoutlet.com. If I do get this combo will I need to replace anything else on the air intake? Will the inlet pipe just connect to my stock setup? Also seeing that I am under warranty do you think it would put it at risk?
Thanks.
I don't see anything else that would need replacing. Your MAF would be just fine. As for warranty stuff, it is a hit or miss with dealerships. Some are pretty cool and others are very anal about that stuff.
Cool suggestions. How was the install, anything serious I should know about? I'll probably have my cousin help me he has all the tools for the job. How do you recalibrate the computer? do you just disconnect the battery or do you have to do something else?
