NIB polished Novi 2000 kit w/extras
chip provenza
87-93 kit Polished novi 2000passenger side kit complete and new
Dual bracket setup
10-rib setup for 10-12 psi/cog pullies also availible 31/73
oil feed and drain set up
polished discharge tube with maxflow bypass valve good to 20psi
Anderson power pipe used
motorsport 42 lb inj green top inj used 77mm pro-m
brand new aeromotive adj fuel pressure reg.
sx fuel pump w/filter fresh from sx
Everything is here to bolt up and go race it.
3k shipped for all.If you dont want certain parts I will discount the blower kit accordingly.But its a way better deal together.
I will not seperate anything unless blower goes first so dont ask.
This blower will make more steam then T-trim vortech's or comparible prochargers.
