NIB Pro Comp Distributor
skip nay
110
Chambersburg Pa
NIB is the Pro Comp Distributorfor your 302. If you are going carb from EFI then this is the distributor for you. New this is $120 and about $13 for shipping for a total of $133. I will ship for $110 or $100 come pick up. Hook it up to your MSD, Mallory, Summit, and or whatever ignition you got!!!
Here is what there site says about it.
Pro Billet 9000 Series Electronic Distributor
Pro Billet Distributors are designed for enthusiasts that are serious about performance.
The PC - 9000 features the following:
CNC machined from Billet 6061-T6 Aluminium to give them precision tolerances, high strength and incredible endurance.
The Billet Distributors are equipped with a large cap that has "spark plug" style terminals for secure wire attachment and maximum protection against crossfire.
Extremely accurate magnetic pickup which never requires adjustment followed by an easy-to-adjust mechanical advance assembly.
Precision weights glide on nylon for smooth advancement and different springs are available so a variety of advance curves can be tuned.
The ?" steel shaft that spins the advance and reluctor is guided by a sealed ball bearing and long sintered bushing.
This combination provides stable timing signals and spark delivery at any RPM.
