Nice Rack
  • Thread starter Thread starter Boosted92LX
  • Start date Start date Sep 12, 2015
First Prev 2 of 2
stykthyn
5,232
2,652
223
gainesville
Sep 21, 2015
#21
  • Sep 21, 2015
  • #21
Reactions: Boosted92LX
Boosted92LX
5,721
4,244
224
Sep 21, 2015
#22
  • Sep 21, 2015
  • #22
Errorz
@madmike1157 I tried to quote your last post and it's so messed up it wont even quote..
stykthyn
5,232
2,652
223
gainesville
Sep 21, 2015
#23
  • Sep 21, 2015
  • #23
The skin filter pulled the rack out
Boosted92LX
5,721
4,244
224
Sep 21, 2015
#24
  • Sep 21, 2015
  • #24
Lol..
Black1987
my wife Bedazzled my input shaft
1,064
595
174
NC
Sep 21, 2015
#25
  • Sep 21, 2015
  • #25
mikestang63 said:
Explain the Taurus tie rods ends... never heard that one before. Thanks
The 93 Taurus tie rods (outer) are shorter than the foxes, and shouldn't require trimming of the treads. They also match the treads of the cobra rack. This is if you are running the original 4 lug set up.
Disclaimer: MM doesn't recommend this set up,because it could potentially cause bumpsteer due to the quality of OEM replacement parts and hasn't tested them.....Mine however did not see this effect. Just making you aware of the claim.
I found this out when researching my 3 link/Torque Arm set up on grassroots and corner carvers and was recommended to do this for the front.
Reactions: A5literMan and mikestang63
stykthyn
5,232
2,652
223
gainesville
Sep 21, 2015
#26
  • Sep 21, 2015
  • #26
What's a good solution to running the cobra rack and you've already upgraded to sn spindles?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Sep 21, 2015
#27
  • Sep 21, 2015
  • #27
I just used Fox inner and outers on mine with my Cobra rack and SN Spindles.
stykthyn
5,232
2,652
223
gainesville
Sep 21, 2015
#28
  • Sep 21, 2015
  • #28
No.bump steer issues?
Black1987
1,064
595
174
NC
Sep 21, 2015
#29
  • Sep 21, 2015
  • #29
If you are running the 94/95 hubs/spindles, then bumpsteer should be about the same. If you are running 96+ up, then the steering geometry requires a bumpsteer kit... (supposedly). Either configuration the tie rod ends on the cobra rack will work with those. If you run the fox or Taurus ends on this configuration you will need a spacer.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Sep 21, 2015
#30
  • Sep 21, 2015
  • #30
No issues, I have 94-95 Spindles on the car.
CarMichael Angelo
8,909
234
Birmingham, al
Sep 22, 2015
#31
  • Sep 22, 2015
  • #31
Boosted92LX said:
Errorz
Happens almost half the time I try to use a iPad to post a pic. It's the stupid iPad that's the problem,...every time I use the pc no problemo.
First Prev 2 of 2
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
