Nitrous Guys Needed..Just wondering...
Manewaymja2
245
Hey Guys
I am currently set up spraying 150 Shot on my 87 stang with all the retard, WOT and RPM switch working just fine. RPM Switch set at 3000 RPM.
My Question is, is there any way in which i can spray say 50 shot off the line and then have the 100 shot come in at 3000 RPM. Want a little help off the line.
Even if this called for a seperate set up (NOS / GAS Solenoid same arming switch) working just of the WOT switch with no RPM switch. That way when i mash it at the line the 50 shot would come in and then followed by the 100 at 3000 rpm. Is this possible?
Thanks Matt
Yes there is. Personally I'd look into a progressive controller, or you could run two stages. Guessing this is a auto launching that low? I would think you should just be able to spray 150 off the line and be fine. Whats your suspension/tires?
Car Is a Stick with T5 Gear Box and Stock Suspension and running Some M/T Drag Radials. I would like to also know what RPM do you think I can Launch at Since you think i can nail the 150 Shot off the line?:shrug:
What size radials? Gears? And you really should work on your suspension, car isn't going to go anywhere with stock twisting up control arms. Its hard to say without that info but you should be able to launch 4500ish...
