I just bought that kit. It's this one right? Lopey4.6, What all did you have to buy to get the nitrous going safely? I wanna make sure I don't blow anything up.
its right if you have a 99 or newer GT , should have everything you need in it . just run some autolite 764 plugs gapped at .035 and dont run over 100 shot on stock engine and you should be fine
Well autolite 764's are a copper plug with the same heat range as stock. I would use a step or 2 colder plug (I run NGK, TR 6's I think). Also A pressure gauge is a must, and a bottle heater if you like in colder climate. Performance will vary dramaticly with different bottle temps.
