  • SN95 4.6L Mustang Tech
Nitrous not hitting hard
  • Thread starter Thread starter Stumbaugh
  • Start date Start date Jun 14, 2010
Stumbaugh
903
Russellville, Ar
Jun 14, 2010
  • Jun 14, 2010
I installed a ZEX kit on my car this weekend. As of right now, I am spraying a 100 shot. To me, honestly, it does not seem to be hitting that hard. I had a 100 shot on another mustang I used to own, and it hit WAY harder than this one. It is a full bottle, NGK TR6 spark plugs gapped at .035. The timing is 2 degreese retarded right now. The bottle pressure was at 1000psi. Here are the only things I can think of off hand that might be putting a burden on this:
Even after the plug change, it still has a low RPM stumble when you are barely on the gas. Which makes me think the COP's are going bad. This could possible be hurting it.
It has the stock 3.23 gears in it. Isnt going to really give it that throw back feel like a 3.73 or 4.10 would. (the old car of mine I referred to had 3.73's)
Still running a stock clutch with 130+ miles. Slips when I powershift on motor, maybe it's slipping a little????
Dont get me wrong, you can for sure tell when I spray it. It just doesnt hit like a 100 shot should IMO.
slayerripkdc
1,341
brewster ny
Jun 14, 2010
  • Jun 14, 2010
You said it. Gears and clutch!
trinity_gt
3,125
81
99
Canada
Jun 14, 2010
  • Jun 14, 2010
Do you have an AFR gauge? If so, what is reading while spraying?
Stumbaugh
903
Russellville, Ar
Jun 14, 2010
  • Jun 14, 2010
I dont have a A/F yet on it. I have only sprayed it about 2 or 3 times. Prob not spraying it again until I can get a gauge on it tho.
Also, the shark valve is mounted 7" from the TB
M
Midnight2V
224
Oklahoma
Jun 14, 2010
  • Jun 14, 2010
If you have the 4.6 shuffle (sputtering and stumbling associated with ignition or vacuum) you should DEFINITELY not be hitting the juice until that situation is 100% resolved.
bhuff30
6,037
35
129
Olathe KS
Jun 14, 2010
  • Jun 14, 2010
If the clutch slips when you power shift it, then I can only imagine how much it slips when you add an extra 150+ ft*lbs of torque from nitrous.
Tim2002GT
635
Tulsa, Oklahoma
Jun 14, 2010
  • Jun 14, 2010
Also, you need to take into consideration that Zex rates their kits hp at the crank. For example, an NX 100 shot is a full 100 hp to the tires, while the Zex 100 shot is more like 75/80 to the tires. My kit is rated at the tires and I use a .052 nitrous jet and a .028 fuel jet for my 100 shot.
N8Dogg98
3,872
238
184
MN
Jun 14, 2010
  • Jun 14, 2010
I suppose it's because you need NOS... two of em... big ones...
Sorry, I have nothing to add as I know next to nothing about nitrous oxide systems... maybe it's time for me to get one and learn
Stumbaugh
903
Russellville, Ar
Jun 14, 2010
  • Jun 14, 2010
haha it's cool. If you ever get nitrous, just dont let Johnny Tran and his motorcycle gang find you in their hood. They will shoot your car up.
Stumbaugh
903
Russellville, Ar
Jun 15, 2010
#10
  • Jun 15, 2010
  • #10
Yeah i totally forgot that ZEX does that. My old kit was a NOS kit and it was rated at 100shot to the tires. Looks like the 125 shot jets are going in.
N8Dogg98
3,872
238
184
MN
Jun 15, 2010
#11
  • Jun 15, 2010
  • #11
Tim2002GT
635
Tulsa, Oklahoma
Jun 15, 2010
#12
  • Jun 15, 2010
  • #12
If your clutch is truly slipping already on motor, I would address that issue before you put any bigger pills in it.
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
